Question about T-Mobile Wing™ Smartphone
Phone won't ring
The volume is on and the sound works since I can still play music and it makes a sound when I receive a text, but when someone calls me it doesn't ring.
  • 5 more comments
  • croat Dec 11, 2007
    You are not alone, I have the same exact problem with my T-mobile Wing. I often play a game of Solitaire on it (how mundane of me) and have a few 3rd party apps installed on it, but don't use them very often. However, the ringing stops almost every single day and if I let it go on without checking (by sliding the left side slider switch up or down to hear the 'ding') I am sure to miss a call. To beat it, I simply turned on vibration option in addition to ringing for all incoming calls. That never fails, unless I'm not near it. At first I was hitting the reset/reboot pin-hole to solve the problem (at least temporarely), but then I discovered that if I go to the Settings screen, Sounds & Notifications and then under notifications tab I simply play the sound I have already selected for the incoming phone ring tone - it starts to play just fine and it works! So, something is causing the built in sound chip to quit reproducing those sounds until you kick it - Fonzie style! I wish someone can explain this to us.
  • Anonymous Mar 14, 2008
    Same problem here. I checked the phone settings to make sure the ring type was set to ring and made sure the ring volume was up, but for some reason it doesn't work when people call.
  • Anonymous Mar 25, 2008
    I've had a the Wing since Nov. of 2007 & have the same problem with the sound cutting out. T-Mobile has replaced the phone twice & each phone has the same problems. I do not have any third party applications installed on the phone. The only thing I've done is sync it wiht Outlook on my computer. I can also go into "sounds & notifications" & play the selected sound for incoming calls to correct the problem. T-Moblile is now stating that it is a memory problem. I would not recommend this phone to anyone.
  • s__y Aug 08, 2008
    I have the same problem with my T-mobile, I did call T-Mobile and they send me a new one, only to see the same problem resurface again on the new one. WHat I have noticed is that the issue happens (almost consistenantly) after plugging the phone into the USB to charge it.
    I used to have very minimal 3rd party apps on the phone and I did remove all of them without any success. I did also try the latest t-mobile upgrade and that did not solve the issue too.
  • Anonymous Aug 19, 2008
    My phone is so random. Sometimes it works; sometimes it doesn't. It rings when it wants and vibrates when it wants. Sometimes I have no clue I received a text/call.
  • specialk1015 Sep 16, 2008
    I noticed this problem with my phone when I put it on silent then put it back to full ring(w/ vibrate). Sometimes it would go on silent right away and sometimes it would ring a couple of times before it goes to silent while it's on full ring. In sounds and notification, it won't play if you just hit play. What you have to do to turn your sound back on is hit the stop button first then hit play(preview) then your sound will turn back on until the phone decides it doesn't want to ring anymore.
  • winged1 Sep 24, 2008
    i also have the tmobile wing and the sound ghas went completely out. I performed the upgrade and it did absolutely nothing... What the **** is the point of spending this much money on a phone for ridiculous stuff like this to happen??
I had the same problem. I deleted my internet explorer temp files, turned the phone off/on, and my phone rang again! Basically, just watch your device memory and keep it as clean as possible. Really bad bug, needs a patch already!
Posted on Apr 16, 2009
My girlfriends did the same thing twice. It's as if one speaker just stops workign so you can't hear it ring but the other one works so you can still hear people talk. And mine goes silent but works if I change the sound and then set it back again. My girl is on her 4th phone. I am still on my first one and she bought hers after mine.
Posted on Sep 17, 2008
Hell yea i had the same exact problem the sound didnt i could make calls and hear what people were saying but it didnt ring . The phone was only a few months old and i had to get it replaced
Posted on Aug 14, 2008
I have a brand new Wing and it does the same thing. Nothing is loaded on it yet. I only have contacts from Outlook synced up with it, that is it.
I hate this phone!
Posted on Feb 25, 2008
Thank you, but even though it's a valid way of finding out (by process of elimination) what it is that's causing it to quit working I don't really have that much patients or time on my hand to be playing with it. There has to be some sort of a way of running a software/hardware diagnostics on the device. It's sort of like the "burn-in" you'd do on a computer before sending it off to a customer. This, I envision, would run for a day if necessary and on a clean device (using the method you described) to see if the manufacturer is at fault. When I say "manufacturer" I mean either T-Mobile, HTC or Microsoft or any other component level manufacturer for that matter. I guess it's just a wishful thinking, but maybe that day will come when someone will figure out a way to put these mobile devices through the same paces that computers are subjected to and find what's wrong with them before they are being sold. I see too many forums where people say the sound quits working and I don't think all of us are running the same 3rd party software that does this to us. And it's not just my HTC manufactured phone model, there are others. The only common theme among them is the presence of Microsoft Windows Mobile 6.0 professional. I'll leave it at that. Thanks for your suggestion.
Posted on Jan 02, 2008
  • 97 Answers
It is definately not speaker related.......i would do a master reset....delete those 3rd party apps....they are likely causeing the do this, go to start, settings, system, clear storage.....good luck! :)
Posted on Jan 01, 2008
My nokia e5 is muted
Make sure it is not in silent mode. And also try turning the volume all the way up. Try playing any music file and try asking someone to call you. If it still won't work, insert a headset/headphone and check if it is working.
Sep 03, 2012 | Nokia E5 Cell Phone
My 8350 was working fine now i cannot hear the phone ring and cannot hear text alerts
make sure the phone isn't on silent by checking the volume level.
Jul 24, 2011 | Blackberry Curve 8350i
When I recieve a message, my notification tone will not ring, it's an mp3 but the standard ones built into the phone also do not work. It's not on silent and all the volume settings are set to max, any...
Make sure that you have set your notification for ring in your phone settings. Most times there are two options one for your call ring and one for when you receive text messages. Make sure you have both set to ring. Also check to make sure that your phone's speaker is working. Try playing a sound off your memory, if it does not work than it is your speaker that is not working and your may need to get that replaced.
May 04, 2011 | Cell Phones
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
Doesn't ring or no sound coming out when I play music. But when I turn it off and turn on there is sound on the intro.
Hi, the ringer of the phone that makes you hear when someone calls or when you want to listen to music is faulty and needs to be replaced for you to be able to hear it ring when someone calls you and when you play your song.
Take care
May 21, 2010 | Cell Phones
I can't hear any sound.And instead of ringing it vibrate.Even I've try to listen song but nothing is happening.
Hi there
First go to your ringer settings to check if the volume is not too low or turned off.
The problem is from your RINGER/SPEAKER,
The ringer/speaker is what brings out sound from your mobile phone when you are called,you receive a text message or you are playing music.
The ringer of your phone is faulty and you need to get a repairer to replace it for you to solve this problem
Thank you for visiting fixya
Feb 25, 2010 | Sony Ericsson K800i Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using!
Try the following instructions, to personalize your Nokia E50!
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info!
Feb 15, 2009 | Nokia E50
T-Mobile Wing™ Smartphone Logo
501 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
