There is an error message ( CHECK PRT / FRNT COVRS ) shown on the LCD screen and on the Fax Machine operating panel cover there is a red light that?s marked (ALARM ) this light keeps flashing while indicating the above message on the screen
    New Friend:
  • 116 Answers
Red light means there is an error. check all covers. open all cover and close again
Posted on Jul 25, 2009
Dcp 7055 brother printer in error - print unable ec
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Note
    In order to transfer data from your fax machine to another, you must have the station ID programmed in your fax machine.
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set.
  4. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Start.
Step2: Verify and Transfer faxes in memory
Step3: Reset the machine After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, do the following based on your country:
<USA>If your unit is still within warranty, try to locate a Brother Authorized Service Center in your area or google to obtain contact information for the appropriate Brother Customer Service Center.
If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
Aug 04, 2013 | Office Equipment & Supplies
How To Repair Error " Print Unable 4F" in Brother MFC-J415W
Sir/Madam
I suggest You Perform Below mention steps To Fix Your brother Printer Issue,
Step1: To clear the message follow the steps listed below:
  1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.
    Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.
If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3.If the error still continues to appear, move the print head and examine under the print head.
NOTE: The images shown below are from the representative product and may differ from your Brother machine,but their inner structures are same.
3-1.Disconnect the Brother machine from the poweroutlet.
3-2.Open the scanner cover.
3-3.Check the print head's position.
In the example photo the print head is positioned at the left hand side of the platen area.
If the print head is on the left side, go to step 3-4.
If the print head is on the right side, go to step 3-7.
If you can not find the print head, go to step 3-8.
3-4.Gently move the print head to the center.
3-5.Examine under the print head. If anything is found, remove it. 1b555a0b-2eb3-488c-883c-4c7db77f04ff.gif
Use a flashlight if necessary to check thoroughly.
3-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
Please contact Brother Customer Service from "Contact Us".
3-7.If the print head is on the right side.
The print head is positioned at the far right hand side, you cannot move it. The machine has a mechanical malfunction and will require repair.
3-8.If you can not find the print head.
Step2: Check if the machine has faxes in its memory
Note
1.Transfer the Fax Journal Report
Press Menu/Set or Menu on the Control Panel of the machine.
Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
2.Verify and Transfer faxes in memory
Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
After the Fax Journal Report and faxes in memory have been transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If your question was not answered, please check...
How do clear the message Unable to Unable to Chang Brother
Or
If you still need Brother Printer Help Then Follow Us On:
Brother Printer Support
Dec 19, 2012 | Brother Ink for Mfc J415w Printer
System error e225
Hello 3G,
To resolve the issue Error e225,
Turn the main power switch off and then back on-ICMF 4000 series/D400 Series
or
Update the firmware :
There is a risk that the MF4150 will not operate if power interruption occurs
during the firmware update. Please make sure MF4150 is connected to
reliable AC power source.
1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
Computer Requirements for update
- Microsoft Windows 2000 or XP (32bit)
- Equipped with a USB port (either 1.1 or 2.0)
- Free disk space: 100 MB or more
2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
5. Make sure the USB cable is directly connected to the MF4150 and your computer.
  • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
  • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
  • You need to log on as an administrator to perform this update.
  • Make sure that no other applications are running on your computer.
6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
  • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
8. Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
9. Confirm that the machine is in the ready status, and then click [Transfer]
  • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
10. The firmware is transferred to the printer.
  • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
  • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
11. When [Firmware transfer is complete] appears, click [Exit].
The printer starts the update process automatically.
<ERASE FLASH ROM> appears on the printer's display while the existing firmware is being erased.
Then printer's display shows <FIRMWARE UPDATE> while updating the firmware.
When the firmware update is complete, the printer's display shows <FIRMWARE UPDATE OK> <MACHINE POWER OFF/ON>
12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
Jun 22, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Canon imge class mf 4150 e225 eroor?
First:
Try to get the latest firmware at LINK.
Here is how to:
8. . Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
Feb 23, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
SAYS UNABLE TO CLEAN
"How do I clear the message Unable to..." ( "Unable to Change" "Unable to Clean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
1. Check for foreign objects, such as a paper clip or scrap of paper, inside the machine.Unplug the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely.
2.If the error continues to appear, the machine may have a mechanical problem.If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. Please make sure you have followed the instructions in the Step1.
3-2.Open the scanner cover by pulling up on the lower right corner of the cover.
3-5.Examine under the print head. If anything is found, remove it.Use a flashlight if necessary to check thoroughly.
1.Press Menu/Set or Menu on the Control Panel of the machine.
2.Press the up or down navigation key until Service appears on the LCD. Then press Menu/Set or Menu.
3.Press the up or down navigation key until Data Transfer appears on the LCD. Then press Menu/Set or Menu.
4.Press the up or down navigation key until Report Trans appears on the LCD. Then press Menu/Set or Menu.
5.The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Black(Mono) Start.
4.Press the up or down navigation key until Fax Transfer appears on the LCD. Then press Menu/Set or Menu.
5.If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3. If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Black(Mono) Start .
3.Reset the machine
Feb 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
When i switchon my machiene an error occured Print Unable 52 please get me out of here regards
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
If the message continues to appear on the LCD, please contact Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Brother Multi-Function Center MFC-240C...
Says: Unable to Clean Consult owners manual
Dec 16, 2010 | Office Equipment & Supplies
Unable to print 5A
Dec 15, 2010 | Brother HL-4040CN Laser Printer
Problems with Canon 7500 Laser Class fax
I have Canon 7000 Laser with Error message #330 which said
SET DOCUMENT??? HELP?
Dec 03, 2008 | Canon LaserCLASS 7500 Plain Paper Fax
126 people viewed this question
jasbo
jasbo
