Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Wont **** up water
I have a bissell power "steamer" and it wont **** up the water it is spraying.
    Problem Solver:
  • 8 Answers
Go to bissell.com go unger frq.asked questions. Also check your belt
Posted on Jul 27, 2009
3 Suggested Answers
  • 24 Answers
SOURCE: bissell power steamer - upright deep cleaner - Does not **** water
If this unit has an onboard heater ( a little red lite in the center of the handle) then most likley it is the problem. You see the heater which is located inside the large portion of the handle has a very small passage that snakes its way throught and heats the water as it passes. The problem is that the water and soap are mixed before the heater which is very very hot and when you turn the unit off and the solution stops moving and hardens in that little passage while the heater cools. To fix this you have to take the handle appart allong with the heater and clean it out. To prevent this in the future make sure to turn the heater off and run just clean water through the unit before you put it away. This unit also has a belt that runs the pump check to see if the belt is in good shape it could be stretched but not broken I would suggest replacing it anyway just to be sure. You can buy the belt allong with other parts for this machine at www.stevessewandvac.com
Posted on Aug 12, 2008
heatman101
  • 43501 Answers
SOURCE: Bissell Power Steamer Proheat Plus not dispensing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dfsghs
Posted on Sep 30, 2010
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray water
Here is a quick link to troubleshooting. http://www.bissell.com/FAQDetail.aspx?id=1196&cid=ccsocial
If you continue to have no spray, here's a link to locating one of our Authorized Service Centers.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 23, 2012 | Bissell 1720-1 Little Green Wet/Dry Vacuum
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
Bissell proheat 7901-1 steamer won't **** up the water
Sounds like either the pump is not working or the collection unit has an air leak.
Apr 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell powersteamer model 1693 not sucking up water
I have the bissel power steamer / powerbrush # on front at bottom 310-3150 bought in october used it 2 times 3rd time it started acting up as follows
cleaned all parts. the spin dial wont spin. the switches on both steamer and hand wand won't spray. Sometimes works then stops. Water comes out the bottom when sitting. All parts look fine no damages.
Jan 10, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
The belt has broken and needs replaced. bissell uses a belt driven pump. ther ar two belts, one for the brush, and one for the pump. all can be replaced through the belt access on the left hand side of the machine.
Nov 05, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
269 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
