SOURCE: Everything works... except the heat!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: microwave doesnt heat anything.
it is the door problem it seems to be known issue per target sales guy he advise to call emerson since it is past 90 days for target to return
Maybe one of the fuses, get an engineer to look at it, for safety reasons.
SOURCE: Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
SOURCE: My kenmore microwave automatically starts and can not be stopped
If and when an oven
is coming on or doing anything by itself, this is very dangerous and
can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If and when an oven
open.
On some models, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly which comes
with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
You can find handy exploded views and get part numbers by entering your full model number at the Sears Parts Site.
A full
Sears/Kenmore model number has 3 digits, a dot, then 8 more digits,
Once you have the Sears part number, you can usually get parts cheaper here.
If you might be interested in having us so the work for you, we charge $39.95.
Feel free to contact me directly.
We're
happy to help you with free advice and we'd appreciate your thoughtful
William E. Miller
[email protected]
http://www.microwavedisplay.com
