Question about GE Profile DPXH46EA Electric Dryer
Ihave a kirkland signature dryer model#seds800jqo dryer runs but
No heat
  • 6,784 Answers
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 23, 2009
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
Our dryer (kirkland signature by whirlpool) quit heating, tumbling, and blowing. When its plugged in you can hear electricity running but nothing happens. the light stil works inside. we have removed the...
soundes to me like the thermal relay has opened. You have to remove the back and check all fuses....some are round some are oblong. remove both wires and test for continuity.
Sep 16, 2009 | Whirlpool Dryers
DRYER NOT PUTTING OUT HEAT
If you can find the wiring diagram inside the rear service panel of the appliance, follow the circuit to identify the overload sensors. There are several internal temperature sensors in the heater circuit that could be open.
Also check that the vent duct, all the way out to the discharge grill outside of the house, is not partially restricting the airflow. Note the same for the lint filter on top as well. Any restriction to airflow will cause poor or no heating problems.
Check for a good discharge of air with everything hooked up, outside where the dryer vent discharges, while the dryer is operating.
Plase feel free to reply your findings, and if you have any additional questions.
Jan 19, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
I have a Kirkland Signature dryer made by Whirlpool. It is about 2 years old. The model number is SEDS800MQ1. The dryer will not heat. All of the other functions are working, it just will not heat. It...
maybe your dryer doesnt like you...
naw im jsus playen try to clean the filter on top or somethin or maybe suttin wrong with your boiler
Oct 06, 2008 | Dryers
GE Profile DPXH46EA Electric Dryer Logo
961 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
