Question about Magellan Maestro 4040 GPS Receiver
My Magellan GPS stucked in the setting mode and there is no way out. Need some help.
    President:
  • 1,111 Answers
Hi tchen2005, try the hard reset first. its the little hole on the side of the unit. while unit is off, use a paperclip the reset the unit. if that does nothing to fix the problem, get the latest update. Magellan has two different updates for the 4040, follow the directions to make sure you get the right one. if you still have the same problem after you install the update, the digitizer is probably broken. hopefully that is not the case, because the digitizer is part of the screen and cant be replaced without replacing the screen unless your very skilled with soldering micro electronics.
if you need further help, just reply to this post.
Posted on Jul 25, 2009
How to set up Magellan Roadmate to Bus mode
If your unit is equipt for this feature, then here is the operation manual link to copy and paste and put in your browser to help you.
http://www.manualbuddy.com/1598/magellan-roadmate-5045-manual
Thanks Mike
Sep 22, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
How do I set up Magellan Roadmate 5045 to pedestrian mode
Thanks for requesting my knowledge to help you. I have located the manual. When you go to this link I am giving you to view on the line manual, you go to page 20 on the manual ( which is point of interest POI) AND look at number 8, this will tell you how to change to pedestrian mode. I am sure this will help you, just follow directions. I could of typed this out, however, i felt that this manual also might help you in other areas you might need. Here is the link to copy and paste in your browser.
Thanks so much, Mike
Shuts down almost immediately after starting even on charge mode...in non-charge mode "battery level critically low"
Hi matchmakers0
this is a very common problem with your model gps
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Apr 17, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Frozen Magellan
Big problem .. you had a bad firmware download and the unit is now stuck in the development mode. Two solutions .. 1) return to Magellan for a replacement. 2) If not in warranty .. there is a third party repair center on the internet .. use your browser and search for 'magellan triton repair'
JG
Oct 12, 2009 | Magellan Triton 500 Handheld GPS Receiver
My Maestro 3225 is stuck on the system settings
if your lucky, all it will need is a reset. start the unit and using a paper clip, insert it in the small hole on the side. if that fails, try the update using the Magellan link below...follow the update directions carefully. you must register your unit on the magellan site to download the update.
if neither solution works, id say the digitizer is bad (the touch screen) but the update normally cures this problem!
let me know if you need further help!
Aug 29, 2009 | Magellan Maestro 3140 GPS Devices
My magellan 3225 turns on, and goes to the system settings page, I cannot get to the main menu. I can go through all of the system settings but that is it
Is your GPS still stuck at the boot screen? Perhaps I can help. Please email me the detailed steps you have taken until you got stuck. My email is kazi at hotmail dot com.
Mar 26, 2009 | Magellan Maestro 3250 GPS
Magellan Roadmate 1412 stuck on settings
There's a small button on a side to reset it to manufacturing setting. Try it. You can also contact magellan tech support.
Jan 09, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Part of cigarette lighter connection stuck
Use a clean ice-cream stick and super glue and pull it out.
Dec 16, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan roadmate 1212
Press MENU then select USER OPTIONS the select SYSTEM SETTINGS then select POWER then select NEVER. This will never let the GPS sleep.
Oct 18, 2008 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
184 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
