Question about Video Cameras
Sony Handycam Video8 - Problems with playback. HELP!
Hi. I have an old Sony Handycam (Model # CCD-TR31), and I am trying to transfer my old tapes to DVD. However, I am having a lot of trouble playing back my tapes. The audio is fine, and there is video...however, the video is flickering on every tape, as if the "vertical hold" is off. It appears this way both on the TV, as well as in the viewfinder on the camcorder.
Is there a way to fix this problem on my own? I don't see any buttons or controls that allow me to adjust the vertical hold on the camera.
Any help would be appreciated. Thanks!
  • devzin98 Jul 24, 2009
    No...this is strictly an NTSC camera.
  • DarkKnightBS May 11, 2010
    Does this HandyCam have an option to record/playback in either NTSC or PAL? Most Sony cameras and camcorders have this option available because of different video formats between the USA and European countries. USA = NTSC (Most of)Europe = PAL France = SEACAM
  • 125 Answers
SOURCE: very grainy playback
This is typical symptom of a dirty video head. this ahappens especially if you play a tape with molds. Cleaning tapes may or may not work. the effectiveness is based on: 1. If the contamination is severe, sometimes the dirt really sticks to the head. You will not normally see this because the head is the tiny part on the head drum that spins. 2. If you use a non original head cleaner 3. If you re-use a tape cleaner. I had this problem on my Sony Hi8 camcorder, i had to mannually remove the dirt on the tape head. I will not recommend to do it as it may damage the head. What I would recommedn first is to buy a Sony head cleaner, and try to clean the head. You may try more than once, it will not damage the head right away. If this does not work, before you send it for repair, ask for estimate. Maybe it is cheaper to buy an analog Hi8 player on ebay rather that send it for repair. And BTW if you have a Hi8 camera, it can play both video8 and Hi8. If you have a video8 camera, it wont be able to play Hi8.
Posted on Jul 06, 2007
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
SOURCE: sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
Posted on Feb 03, 2008
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Posted on Jun 21, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Handycam CCD-TRV87E
Its analog model of Sony camera series and you can not download its video in PC directly. You can connect Digital Model camera with PC.
Posted on Aug 06, 2008
Everytime I press play during playback it will play for a little while the starts beeping and stops
The unit likely has a problem in the transport mechanism which moves the tape. Maybe time to retire this unit?
Apr 30, 2012 | Sony Handycam Ccd-tr600 Hi8 8mm Video8...
Sony handy cam Hi 8 ccd trv308
Sony has a recall on some of these ccd imager problems. Contact Sony to see if your model applies, but it sounds like an imager problem on your pal format camcorder. Larry
Apr 19, 2010 | Sony Handycam DCR-SR220E HDD Camcorder
Hi how can i transfer my video files from my sony handycam vision video 8 XR model CCD-TRV57. I do not have drivers for the said unit to be transferred to my PC. Thank you and more power.
I have an old video camcorder. Sony SteadyShot Handycam Vision. Model CCD-TRV57. The screen flashes C 31:23. Can anyone help me with this problem?
Apr 02, 2010 | Sony Handycam CCD-TRV57 Camcorder
Moisture symbol on very old sony cam
I have a CCD-F385E with the same problem i kept putting the tape in and out and it started working.
Nov 25, 2009 | Sony Handycam CCD-TRV81 Camcorder
I have a Sony Video8 Handycam CCD TRV211.
If you are asking about CCD-TRV211 camcorder?
CCD-TRV211 is analog Video-8 camcorder so its movie data is not digital and can not be connected directly with computer via USB port.
Best and easiest was is to connect camera with DVD Recorder and burn DVD, this will convert analog movie file into digital data and you can copy it to hard disk of computer.
Mar 31, 2009 | Sony Handycam CCD-TRV308 Camcorder
Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
MY SONY DCR-TRV140E WILL NOT PLAYBACK MY OLD VIDEO8 (PAL8) TAPES?
Vista should be able to download this without any issues as it already includes the drivers. i was able to do this with my sony dcr-trv250 painlessly over the ieee-1394 (firewire) port using the DVD capturing bloat-ware (Ulead DVD creater) Toshiba had already installed for me. My toshiba satellite is running Vista Home Premium.
as regards analog hi8 playback, the product manual for the 250 says that this is NOT supported, i.e., it CANNOT play back analog hi8 tapes. Also, i wonder if PAL would be supported here in the US (assuming you're in the US, of course). I would expect only NTSC support. but it's a moot issue, since it doesn't play analog
Oct 03, 2008 | Sony Handycam DCR-TRV140E Digital...
Sony Handycam Model CCD-V801 does NOt Play
Hai, Check with previous recorded tape, If it is not playing. Clean video head with head cleaning cassatte. Before that please check is it going to VTR mode & also is it takes play indication. Then check with pre-recorded cassatte. thank you best of luck udupi
Mar 13, 2007 | Sony Handycam CCD-TRV81 Camcorder
Video Cameras Logo
920 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
