Setting up NEW 19" INSIGNIA TV/DVD COMBO No Signal, Sound
My 19" TV/DVD combo , (no cable), will not get a signal. Which of the two cables is a coaxial cable? Where should I connect it? I am a low vision person.
Thanks.
  • 118 Answers
This is the coaxial cable
Setting up NEW 19
Posted on Jul 23, 2009
What channel does the tv need to be on for the hmdi cable to get a signal?
It's not a channel. You should select the input to TV to HDMI. Refer its user manual, please.
Electro help
Sep 21, 2014 | GPX KCL8807DT TV/DVD Combo
Not getting any channels. just a blue screen with the word signal on the screen. what might be wrong?
It is telling you that your connection cable/antenna is not connected to the set. It is not receiving a usuable signal.
Jan 10, 2011 | Polaroid 1913TDXB 19 in. LCD TV/DVD Combo
My Naxa NX-546 LCD TV/DVD combo no longer has sound. I've tried every menu option I can think of. Any idea what could be causing this?
Tries unplug,replug tv back about an hour later.The tv should be resetting itself back to factory setting,sound should work now.Still have the same problems.The tv Tuner signal board is shorted and the causes.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 28, 2010 | Naxa Electronics NX-546 20 in. LCD TV
Can I use this TV in Argentina? where the transmission system is PAL-N vs. NTSC M of USA?
No,will not work,if PAL frequencies signal.NTSC frequencies signal only work in US,Mexico,and Canada.So,sorry no.
Sep 06, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
No picturejust blue screen but get sound
CHECK all connections to and from TV!
Signal INTO dvr/vcr combo from source(cable sat. etc.) and OUT to ( TVinput )
May 19, 2010 | Insignia IS-DVD1001 DVD Recorder/VCR
Digital labs 19 inch tv/dvd combo
Wish I knew the answer ... I have the same problem after switching to Dish Network (Satellite). It worked fine with Time Warner Cable. I'm suspecting the signal over Dish is analog (NTSC) which is not supported by this particular TV. I wish I still had the box and receipt!
Feb 01, 2010 | Televison & Video
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Dark blue screen with words: Cable, Digital TV, No SIGNAL. Brand new TV.
that says it all... no signal look at your owner's manual to set it for TV
May 22, 2009 | Initial DTV-322 32 in. TV/DVD Combo
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
