I have had my projector for abourt 2 years and the projector indicated that the bulb life was almost up and had to be replaced. I bought the new bulb and installed it with no problem. when I turned on the projector the bulb did not turn on and the Lamp LED and the Temp LED flash on and off constantly. I've unpluged the projector and repluged without any change. Although the lamp light does not turn on, I placed a dvd in the player and the DVD does'nt rotate. So the problem is not the Bulb. I dont see any fuse on the Projector. Could there be some way to reset the projector?
  • 1 more comment
  • handycap3 Jul 23, 2009
    The make and model of my projector is: Optoma Movietime DV10 Multimedia Projector.
    I do not see a restore button on the projector. The LED's for Temp. and Lamp are both flashing at the same time at about one second intervals.
  • handycap3 Jul 24, 2009
    I changed the bulb back to the one that was origanally installed and the projecter sill won't turn on. I suspect that the problem may be some kind of fuse that is blown.
  • 2,359 Answers
Please ADD the make and model of your projector on the comment page.
Without the model information,I can only give you few location to check on.
Check for an air filter or air clear.
Some unit has the smart to sense for filter change. In general you must do both at the same time.
(once again this is general info. Without the model #,I only can tell you to look for the filter)
The next item is check for safety switch/latch for open. The project has built-in safety.
Make sure all door/latch are close securely.
Do a quick cleaning and check for loose parts.
Please ADD the model number under comment page.
I will follow up later.
Posted on Jul 23, 2009
  • 2 more comments
  • Vincent_G
    Vincent_G Jul 23, 2009
    Thanks.
    Press RESTORE then ENTER will factory default this Optoma DV10 Projector.
    Is the warning LED indicator showing anything.
    The following is from the user guide
    Warning Indicator
    ▀■ When the “LAMP” indicator lights solid red, the projector will
    automatically shut itself down. Please contact your local reseller or
    service center.
    ▀■ When the “TEMP” indicator lights solid red for about 20 seconds,
    it indicates the projector has been overheated. You will see a
    message “Projector Overheated. Lamp will automatically turn off
    soon.” on the on-screen display. The projector will automatically
    shut itself down.
    Under normal conditions, the projector can be switched on again
    after it has cooled down. If the problem persists, you should contact
    your local dealer or our service center.
    ▀■ When the “TEMP” indicator flashes red for about 10 seconds,
    you will see a message “Fan fail. Lamp will automatically turn off
    soon.” on the on-screen display. Please contact your local dealer or
    our service center.
    I will check for more comment later.
  • Vincent_G
    Let's back track a little bit here.
    Please put the old DLP lamp back into the unit. According to your org post the lamp is getting old but not POP yet.
    Please put the old lamp back.
    The reset info I send you is FROM the screen.
    I got the pdf file front of me now.
    I'm doing few project and I can help you to troubleshoot until 5:00pm PST or after 9pm PST.
  • Vincent_G
    Vincent_G Jul 24, 2009
    Can you do board level component troubleshooting?
    Can you identify the thermo fuse and temperature sensor?
    Did you do a quick cleaning and check for loose parts?
    or fragment of part(s) inside the unit?
  • Vincent_G
    Vincent_G Jul 27, 2009
    Are you able to do a clean up and check for loose part(s) inside the unit?
    The instruction I gave you is a keypad movement on the remove......since the bulb does not light up so you can not see the image and make the correct movement to reset.
    Please do a quick clean up and look for broken part(s).
    You can add comment later.
    I will follow up on it.
When its turned on blinks red about every 2 seconds dark screen
It is probably the projector bulb. The two red blinking lights indicate bulb failure. Replace the bulb and also thoroughly clean the cooling fan and vents to prevent future overheating which can shorten bulb life.
Hope this helps.
Bob
Oct 02, 2015 | Office Equipment & Supplies
Dell dlp front projector model 2400mp parts
The bulbs are very costly and they have a short life as is. Stop replacing and get a new unit. The repair is not worth the cost and a new unit has a warranty for at least a year.
Feb 27, 2014 | Office Equipment & Supplies
HOW RESET THE TIME OF LIFE HRS TO THE LAMP INSHARP ANC55LP PROJRCTOR
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 08, 2013 | Sharp ANC55LP Projector Replacement Lamp
My projector's power light is red, but when I click power it won't turn to green (on)
The likeliest problem here may be a burned out or failed projector bulb. Most projectors will fail to power up at all when if the bulb is out. The HD20 user manual does not specify a red light as an error indication option however, generally amber.
User manual .pdf is located here (takes a bit to download for it's size), Projector Status Indicator instructions are located on page 40.
Here on the product page itself, an email to Optima support may be warranted given the red instead of amber error light.
If you had any messages recently indicating your bulb life was nearing it's end, again, this would be my first guess. Certain models of projectors do have a tendency of blowing through bulbs even before any warning message comes up. I had an experience with a certain brand/model that for the last 3 replacements has given only about 1/4 of the stated bulb life, so unfortunately it does happen.
Mar 05, 2011 | Optoma HD20 DLP Projector
Our projector indicates that the light bulb needs to be replaced after replacing the light bulb once it still indicates that it needs to be replaced.
This is the excerpt from the manual on how to reset the lamp life timer.
Turn on the projector and use "Lamp Reset" after the lamp module is replaced.
Lamp Reset: (i) Press "Menu" ?§ (ii) Select "Options" ?§ (iii) Select "Lamp settings" ?§ (iv) Select "Lamp Reset ?§ (v) Select "Yes".
Jan 12, 2011 | Optoma HD65 DLP Projector
Exploding Bulb
remove the top of the projector (remove the 6 screws on the bottom and the top 2 screws on the back), use canned air, and blow every piece of dust out of every nook and cranny. also, don't get cheap lamps from "bob's house o' lamps". get the AN-XR10XLP/1 from a sharp dealer to get the full life out of a lamp. also, make sure the vents on the projector are not blocked when you use it.
Mar 20, 2009 | Sharp XR-10X Multimedia Projector
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
I have a sony kf42e200 rear projector tv and the display is appearing red at the top of teh screen and blue at the bottom. I'm assuming it is the bulb and it needs to be replaced, but the tv is only a...
the 10 years is supposed to be the life span yes but sometimes they go bad due to a fault in the yv itselfyou would be better off buying another tv as the cost to repaur that one will run about the same as a new tv
Nov 05, 2008 | Televison & Video
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
Televison & Video Logo
252 people viewed this question
Top Televison & Video Experts
