Question about Whirlpool RBS305PDS Electric Single Oven
OVEN WILL NOT HEAT
I have a Whirlpool RDS305PDS that will not heat, the digital display works but the over will not heat
    Scholar:
  • 83 Answers
Is it a gas or electric model? If it's gas it will be the following;
Check to make sure the oven clock is set as manual not automatic, if it isn't then this is the problem.
A faulty solenoid valve that is controlled by the oven thermostat knob. You need to get a qualified gas engineer in to take a look.
If it's the electric model, then it will be a faulty element. You need to get a qualified electricain in to take a look.
I hope this helps.
Steve
Posted on Jul 23, 2009
The oven will not work, power is on, stove top works, light works, display is off, no heat. The control lock and delay feature is not set
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 10, 2011 | Whirlpool GBS309PVS Stainless Steel...
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jul 22, 2010 | Whirlpool RBS275PD Electric Single Oven
No heat! Lights work, timer etc - everything "appears" to be working but there is no heat!
Probably your heating element has failed, dependant on appliance the element can be found in the oven itself at the back behind a panel that normally has a couple of screws holding the panel in place. reasonably easy to fit yourself and not very costly.
Hope this helps
Apr 01, 2010 | Whirlpool RBD305PD Electric Double Oven
Error Code (do or) on display
There are two door switches the primary and secondary interlock switch. HEre is the cabinet break down.
Diagram #51 and then Page 7 on this page
Hope this works for you
Feb 14, 2009 | Whirlpool GMC305PD Electric Single Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Dec 12, 2008 | Whirlpool AKZ159IX Oven
Re: my whirlpool digital oven
The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
Jun 24, 2008 | Ovens
Cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Aug 25, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBS305PDS Electric Single Oven Logo
63 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
