Question about HP OfficeJet 6110 All-In-One InkJet Printer
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
    Sergeant:
  • 168 Answers
All of the printers in this price class are of about the same quality. The replacement for the 6110 is now a 6410 or possibly 6510. The price has fallen to well under $150. Repair would cost upwards of $400. You be the judge.
Posted on Jul 23, 2009
Hp 6110 All in one printer: My 6110 gets "stuck"
I m sorry
your printer is near end of its life
you need to replace scaner mechanism
that cost as a new printer
try on/off until it will never start again
Pls vote us to keep us alive
Nov 20, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP office jet 6110 all-in-one Scanner Failure message cannot be erased. When power is switched off/on makes load grating noise and Scanner Failure message reappears. Copier function will not work either.
Print head sticking needs oil on shaft that its slides on. Open cover and put a drop of oil on each side print head Shaft cut it back on and see if this helps .may half to do this 2 or 3 times to get the oil on to bearings . They dry out over time. Good luck
Aug 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 scanner making noise i can do any thing else because of that scanner light doesn't move, move little on scanner glass then come back on right hand side and keep making noise some time i can see...
If you cleaned the scanner glass before the problem began, it sounds like you messed up the homing strip underneath the glass. The scanner is trying and trying to find its home position and it can't. There is no way to disable the scanner to use the other functions. This is the downside to All-in-One machines. If one function (most commonly the scanner) stops working the entire machine won't work. I own a Cartridge World ink refilling store and I always caution people against buying all-in-one machines for this reason. It sounds like you'll need to buy a new printer, unless your printer is magically still under warranty you could call HP and ask what they can do for you. They'll probably just recommend you buy a new machine anyway.
Feb 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Fax Error 386, HP 6110xi Fax failed Is there a solution?
See http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
Too much noise on the phone line: e.g. bad connection, unshielded phone cable next to a electrical machine (motor!), temporary problems in phone service providers network.
Fax is essential data transmission by beeping noises. If crackling on the line or other disturbances degrade signal quality too much, the data cannot transmitted properly anymore.
Feb 09, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hi do you recomend i buy a second hand hpg85 seller says its in perfect working condition. My concern is: how old is this machine and are the parts still available should i require them.On offer is also a...
I bought my G85xi in 2000 from Costco. I have used it with care & have had only a few problems with it (bad cartridge once, dried out cartridge once, bad FAX board which was replaced under warranty). The quality of the printing, etc is excellent. I've been using the large color #78A cartridge (38 ml.) from Costco which costs about $53. A pack of 2 black #45 cartridges is about the same ($52) (42 ml.)
I also bought a slightly used G85 from a flea market (mainly for back-up parts). I have an hp 6110 all-in-one bought in 2005 which is better than the models produced today, but not as rugged as the G85. Also, HP has rigged the newer models (including my 6110) so that you can't do any printing if the cartridge is determined to be low in ink. to make matters worse, they don't tell you which cartridge is low - only give a message to "remove & relace the cartridges".
Oct 19, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
I have the same priblem
Check these FAQs for your printer: Also check the links at the bottom of the FAQs for more troubleshooting advice.
Sep 10, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 2115 - clicking noise from carriage, can`t print test page
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
HP 6110 error message "clear carriage jam"
No one from "FixYa" provided me any useful solutions to try. Following the HP reset instructions many cycles did not work. By accident, I finally got the HP 6110 working again by unplugging it from the Monster brand surge protector power strip, depowering both for a period of about one hour, then repowering the power strip, then plugging in the HP 6110 and going through its reset function once more. Plugging the HP 6110 directly into the wall outlet into which the power strip was/is plugged did not solve the problem. Note that gremlins in that same power strip also adversely affected my ZyXel DSL modem, or perhaps spurious backfeed signals from that DSL modem affected the HP unit. Sorry, I'm not able to provided any explanations as to why this worked; I am not a digital/PC'electronics person. I was about to tear the machine apart to clean all the surfaces and mirrors as others had recommended, or buy a replacement.
Dave R.
Dec 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Grinding noise
I have the same problem - always after power failure - can anyone help?
Jul 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
250 people viewed this question
Seeker5211
Seeker5211
