Question about Canon PowerShot SD990 IS / Digital IXUS 980 IS Digital Camera
Lens error, cannon camera
I have a Cannon powershot A550 digital camera, my brother dropped it and the lens is half open and half closed. whenever I startup my camera the screeen displays a message that says, "lens error. restart camera". I have also run out of warranty and i don't wanna pay for the repair. Please tell me a possible solution to fix my camera.
  • doggitydogs May 11, 2010
    Please post this under Canon PowerShot A550 rather than Canon PowerShot SD990 IS. As for your problem, is the lens retracted with the shutter open or is it out with the shutter closed?
  • 6 Answers
SOURCE: lens error message Canon Powershot A550
Canon A550 and A560 have the same body and most of the internal parts, including lens assembly are the same. Canon won't sell individual parts within the lens assembly. There could be two possiblities. One is (unlikely) that the lens assembly components have been knocked off from their position. The other is that because of a knock, or dropping the camera, the gears in the gearbox of the lens assembly are broken. These gears are the same as the ones in A530/A540, and are available from ebay for $12.50 including shipping. Checkout my site for how to open up the camera and the lens assembly to replace these:
http://pkrobot.freehostia.com/MiscElectronics2.htm
For A550 and A560, if you take it to the professional repair shop, it might not be cost effective, since it might cost around $90. Canon does not sell gears, so they might have to replace the entire lens assembly. The new camera is available these days for around $140.
Posted on Feb 17, 2008
t00nz
  • 4738 Answers
SOURCE: help
Here's the support site for your camera. Click on the "Downloads and Drivers" tab, select your operating system, and then download the appropriate driver for your system (note some OS don't require a driver.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=11125
You can also download the "Zoombrowser" program here, but it's 72 megs, and might take a while.
Posted on Feb 23, 2008
  • 9 Answers
SOURCE: Canon PowerShot SD600 Digital Camera
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Posted on Mar 08, 2008
welcomejee
  • 10594 Answers
SOURCE: need to download photos off of cannon digital elf to vista dell
No update released yet for Vista at Canon Support. May be later...
Posted on Dec 11, 2008
  • 13 Answers
SOURCE: my cannon powershot A550 won't download into my
download the proper software for it
Posted on Aug 14, 2009
'"The lens of my cannon
This is basically the infamous Canon "E18" error, which has been around for quite a while.
I would type out my own suggestions but since it's such a common error I'll just direct you to a nice long list of solutions already compiled elsewhere: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 01, 2011 | Canon PowerShot SD1000 Digital Camera
Lens Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
May 28, 2010 | Canon PowerShot SD1000 Digital Camera
PowerShot G5 Digital Camera: Cannon power shot will not turn on and lens were n...
there is a switch inside the battery cap, when it open, the switch is turning off, then switched on when it closed. the camera wouldnt turnd on, when the swich not working normally
May 18, 2010 | Canon PowerShot G5 Digital Camera
Cannon powershot SD1100 IS it displays the
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Nov 24, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
I Have A Cannon Camera. And It Wont Turn Back On!
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 17, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have a cannon powershot a 85 it was working fine then nothing i turn it on and it lights up the cannon sign then goes of. it is showing E18 in bottom legt hand corner. i have tried both rechargable and...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 22, 2009 | Canon PowerShot S2 IS Digital Camera
The lens on my Cannon SD sure shot wil not close
Lens errors are fairly common for all digital cameras. Usually it's sand (be careful at the beach) or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jun 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Cannon PowerShotA50 trouble
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 24, 2008 | Canon PowerShot A50 Digital Camera
Canon PowerShot SD990 IS / Digital IXUS 980 IS Digital Camera Logo
212 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
