Question about Boating
Volvo 2003 marine diesel problem starting
Volvo 2003 marine diesel problem starting after leaving for a day.It normallydraws diesel from below engine level so I set up a head tank but got called away and when I came back the diesel had drained into the lower tank through the fuel lift pump,filter,injector pumps and pipes.
  • 5,520 Answers
It sounds like you need to vent the pipe before the fuel lift pump so the vent is open when the pump is off. That way the fuel can not siphon to the lower tank. Then you would need a valve in sync with the lift pump to close the vent so the pump can draw. Perhaps there is a lift pump with that feature built-in.
Posted on Jul 25, 2009
Looking for info on replacing engine in cs36 sailboat with a Volvo saildrive is this possible?
you may get it from the net but I personally would find a marine volvo dealer or a good marine shop that handles volvo products and discuss what you want to do with them
the drive section will be or should be made to a standard fitting so that other motors can be fitted or there would be adapters made to fit other engines
face to face or on the phone is the best way to start resolving what you want as all the problems can be answered as you go
Jan 24, 2016 | Volvo Cars & Trucks
Isuzu c190 wont start when warm
C190 is a 2.0 L OHV 8V engine same as marine 4AA1.
when warm did you try diesel test fuel?
runs now , right, or runs and stalls. right?
that be the biggest clue there.
besides black smoke.
lost compression hot.
or lost fueling hot.
simple test for compression and test fuel....... leaving what?
Oct 10, 2015 | Isuzu Cars & Trucks
Cummins Marine Diesel 6BTD Engine
Nowhere, Service manuals are several hundred pages. If you own the engine then you need to purchase the manual.
Jan 22, 2014 | 60 series Diesel Power Service Manuals...
What are the main manufacturers of diesel engines for boats?
he main manufacturers of diesel engines for boats: Caterpillar Marine, Cummins Mercruiser, Detroit Diesel, John Deere, MAN, Westerbeke, Mecruiser Diesel, John Deere, Volvo Penta, and Yanmar.
For more information on these manufactures, check out these websites: http://marinefuel.com/marine-engine-manufacturers-diesel/ and http://www.discoverboating.com/buying/types/engines.aspx?id=80
Feb 06, 2013 | Boating
Volvo s60 2003 - Without warning the car won't start but when you leave it overnight it appears to be okay. Clock runs sporatically and different msgs such are airbag, alarm was going off, removed
Sound like you are dealing with a bad battery connection,or even a bad ignition switch,Volvo at your year had ignition related problems where the ignition switch would go past position 1,this was due to ingition column lock,On your type of make and model it is not adviseable you crank the engine,and recrank the engine if it not starting your immoblizer is done every one key ignition cycle,and can create false message,or DTC (trouble codes),
Aug 12, 2012 | 2003 Volvo S60
I need to find a free repair manual online for a volvo penta motor 1979
i have a fivehorese penta outboread engine is it water cooled or air cooled
Apr 01, 2011 | Volvo Boating
Hi there, I`ve got a problem with cold start my Volvo, MY 2003, D5, 2.4 Turbo Diesel. After overnight parking, outside temp. is 10C or less engine wont start - when I`m warming up temp. sensor by...
Sounds like a faulty injector, had the same problem about 2 years ago cost over £1500 to have new injectors fitted.
It might be worth trying some redex or similar cleaning product incase its just blocked.
Dec 04, 2010 | Volvo V70 Cars & Trucks
Hello! i have a problem whit my volvo s 40 1.9 TDI year 2003. some times my car can't start ,when engine is hot , when i turn it off and try it to start again. I don't getting any service lights warnings ....
Diesel engines rely heavily on the fuel pressure, it sounds as if the pump is not putting out the pressure when it is hot, there for you have to crank several times to build the pressure up. You would want to have the pressure checked, of course when it is hot, and then you can go from there.
Sep 29, 2010 | 2003 Volvo S40
Volvo s40 2003 diesel. all of a sudden it is very slow accelarating from a stop start. there is no pull what so ever. any ideas please.
Could have several problems. Need to have it scanned before you really know which direction to persue.
Sep 14, 2010 | 2003 Volvo S40
Volvo Penta marine diesel 2003T engine has diesel in sump
I owned one diesel engine. I would say the engine siphoned the diesel after it was shut off.
The throttle controls may not be closed. The injectors were tested for their opening and spraying, but were they tested for closing and sealing when off? Diesel fuel lines maintain a vacuum or they get air bubbles. Cooling cylinders create a draw right into the crankcase. Last idea-crankcase vent clogged
May 11, 2009 | Boating
Boating Logo
278 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
