Back to:
Tags:
D-Link AirPlus DI-614+ Wireless Router
Firewall settings
posted by edgerider on Nov 21, 2007
I want to turn on my firewall on my router. I don't think I did it when I first set it up, and it is an unsecured connection for anyone to use on my wireless network. I want to make it password protected. Help??
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 21, 2007
Not Rated (0)
rocker ramji
Rank:Wiz Wiz
Rating: 79%, 211 votes
sure u can set ur router through WWP or WPA secured prodected no need to enable fire wall>
connect ur pc through hard wired on the routers ether net port and open a browser window and in the address bar type 192.168.0.1 hit enter u can see ur router login screen
user name-> admin (lower case)
password-> admin (lower case)>and hit enter
and go to wireless in the screen under Authentication select WEP enable
select key 1 and in teh box type 10 digit security no or name which u can remember always and click on apply and reboot the pc and laptop and ur network is now secured rate me soleved if its helps thx
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Firewall settings:
I don't want to Accept this solution
Can you Help with these Routers problems?
Routers
every time i when i type in the ip adress it says its...
Routers
I have a d-link DIR-615 Wireless N Router and i am...
Routers
keep getting error reports during startups, replaced disk...
Routers
I set up BroadVoice internet phone, show:start your web...
i have a ps3 but it wont let me get on line. every time i...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
