Question about Dyson Vacuums
My Dyson V7 vacuum has just recently started working but with an intermittent suction only, not running consistently.
    Master:
  • Dyson Master
  • 850 Answers
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner running intermittently. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Mar 26, 2017
Runs while holding the suction part toward the ceiling and shuts off as soon as I put it facing down
Hi Lynette, it's Jack at Dyson.
I'm sorry to hear your DC31 seems to be working intermittently like this. To determine which part may be at fault we'd need to take you through some quick diagnostic checks over the phone when you have your machine to hand.
To speak with our experts directly you can reach the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 17, 2014 | Dyson DC31 Bagless Handheld Vacuum
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My vacuum will not run continuously
It should still be under warranty so take it back to the suppler, distributor or Dyson if you are near.
Apr 29, 2013 | Dyson DC44 Animal Handheld Vacuum Cleaner
My Dyson 41 has just started only sucking through the tube
We've had our DC41 for 4 months now and suddenly noticed no suction at the base as well. Base motor works fine.Thought I'd take one last look before sending in for repair. At the base of the attachment hose near the motor is a small red tab. I depressed it and pulled the entire hose off the motor. Sure enough inside was a eyeliner pencil our daughter had unknowingly vacuumed up. I couldn't see it just peering the length of the hose. Even with a flashlight. You don't see mention of the small red tab but it allows you to see close up rather than peering down the hose if something is lodged near the motor. Apparently this pencil prevented the internal hardware to switch from wand to base suction when the handle is reclined in floor vacuum mode. These vacuums have strong suction and they will pull up the oddest things! Hope this helps!!
Aug 14, 2012 | Dyson Dc 41 Ball
I have a dyson 07. Vacuum works fine, great suction using the hose. How do I switch to using the carpet vacuum. (I lost my instruction book) Thanks
If this unit has a suction hose built in to the handle, the carpet vacuum should start working after you return the handle hose to the proper position.
Dec 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction
There should be a sponge like filter in the area of the canister and no this is NOT the HEPA filter. When you find this other filter you will want to bang it off outside and then put it back in and you should be all set.
Jan 17, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Our DC17 is loosing suction. How many filters muist be cleaned?
This video is for replacing the clutch & belts, but it also shows how to take out the hose underneath & inspect it for holes or damage to see if that's causing suction issue http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Nov 06, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Vacuums Logo
66 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
