Question about Dyson Vacuums
My Dyson V7 just started making intermittent suction sounds then shuts down.
  • 97 Answers
SOURCE: Dyson DC07 works and cleans fine, but motor makes loud screaching sound.
If the screeching noise is happening at all times, it is most likely a motor failure; which unfortunately can only be resolved by complete replacement of the motor.
If it's a loud ratchety-screeching type sound, and is only occurring when the brush is set to carpet, it is most likely due to an obstruction of the brushroll or a problem with the clutch. Ensure that the brushroll can spin free, look for anything physically blocking it. Check the bearing ends on the brushroll, they can melt and cause the brushroll to not spin effectively. If neither of those two things resolves the problem, the clutch most likely needs replacement.
-R
Posted on Jul 31, 2008
SOURCE: Dyson DC07 shuts down after 5-10 minutes of use and horrible suction!
I have had this problem on two dysons and have solved it by replacing the so called lifetime pre-filter. The problem is not the washable blue sponge but the material gauze filter in the plastic surround.
To see if this is your problem try removing the whole filter (i.e. the filter with the blue sponge inside - you need to remove both bits not just the sponge).
If you do a quick vacuum test for a few minutes then see what effect this has on the suction.
If you need a new part try somewhere like here (you'll need to chose for the right model) : http://www.espares.co.uk/part/dyson/dc07/p/1086/716/6/420625/875479/lifetime-pre-motor-dyson-.html
As I say this has fixed both of mine.
Posted on Nov 11, 2008
  • 55 Answers
SOURCE: Dyson dc04 motor runs but has no suction.
I would make sure it is the motor first by isolating the sounds to just the motor. Take off the dirt cup, both filters, and belt, then run it and see if the sound is still there. If it is, you need a new motor. If it isn't, you need to look for a clog, or bad roller bearing.
To take the motor out first undo the wiring running down the backside of the unit inside of the switch housing. Then take the four screws out that hold the outer motor housing on, and the rest pops apart. Once you get inside, the gaskets make it a really tight fit, so you might have to hit the motor shaft with a rubber mallet to get it out and use penetrating oil on the bottom gasket to get the new motor to slide back in.
I guess there is no easy explanation. Let me know how it goes.
Posted on Dec 01, 2008
tvservice306
  • 458 Answers
SOURCE: wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Posted on Nov 07, 2009
Dysonteam
  • 167 Answers
SOURCE: A Dyson dc 17 Animal and the wand/hose has lost suction
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 20, 2010
My Dyson V7 vacuum has just recently started working but with an intermittent suction only, not running consistently.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner running intermittently. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 18, 2017 | Dyson Vacuums
I just cleaned out my Dyson animal, which had no suction. Now, all put back together, the suction is there but the machine makes a long lasting sound when I shut it off.
Hey, It's Jim with Crucial Vacuum,
If you're hearing an odd sound that is somewhat prolonged after you turn off your vacuum it be that your belt or brush roll needs replacing.
If you have suction and there aren't any clogs in your vacuum your belt might be worn and loose, which could give off an odd noise as it slows down along with the brush roll upon you turning off the vacuum.
Does your Dyson DC14's belt lack tension? It may be hitting the brush roll at the wrong angle. Same deal with the brush roll itself. Turn your vacuum over and take a look at the bristles. Are they loose or worn down? These are indications that its time to change these two parts of your Dyson DC14.
If these parts aren't in top shape or attached properly they're bound to make a number of odd noises.
We do offer low cost high quality replacement parts for Dyson DC14's. They can be found at the below link:
http://www.crucialvacuum.com/dyson-dc07-clutch-belt-set.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 16, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Machine shut off when suction release button was accidentally pushed. Now it won't come back on! What should I do?
Hi there, it's Jack at Dyson.
The issue you've described sounds very unusual. DC23 has a suction relief trigger underneath the hand grip of the wand handle, but this isn't connected to the vacuum's electrical components and shouldn't cause the vacuum to cut out in use.
However like most Dyson vacuums, DC23 is engineered to shut off for protection if it starts to overheat. This may occur if the machine is used when blocked, or if the filter is overdue for a wash. It should reset automatically after it's had around 2 hours to cool down, but to prevent it from happening again please follow the steps shown in our online support guide: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/check-telescopic-wand-step-1-turbine-head
In normal use, we recommend washing the lifetime pre-filter at least once every 3 months using cold water without detergent. Allow at least 24 hours for the filter to dry completely before replacing it.
I'm confident following these steps will resolve the issue, but if you'd like further help or advice after giving this a try, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 08, 2014 | Dyson DC23 Animal Vacuum
Switching on and off no suction
Like most Dyson vacuums, DC14 is engineered to shut off if it starts to overheat. This could be due to a blockage, and the filter may also need a wash.
In normal use we recommend washing DC14's pre-filter at least once every 3-6 months using cold water without detergent. Allow at least 12 hours for the filter to dry completely before replacing it.
To check for any blockages, follow each of the steps shown in our online support guide: http://www.dyson.co.uk/support/dc14/dc14-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
If you'd like some further help from our experts after giving these steps a try, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide assistance.
Aug 06, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
Suction stops when vacuuming with the DC40 model
There may be a clog where the air flows from the brush roll into the vacuum
Jan 29, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Runs while holding the suction part toward the ceiling and shuts off as soon as I put it facing down
Hi Lynette, it's Jack at Dyson.
I'm sorry to hear your DC31 seems to be working intermittently like this. To determine which part may be at fault we'd need to take you through some quick diagnostic checks over the phone when you have your machine to hand.
To speak with our experts directly you can reach the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 17, 2014 | Dyson DC31 Bagless Handheld Vacuum
Dyson DC17 Animal does not have enough suction from the wand handle to power the mini turbine head. The wand handle has very little suction.
It sounds as though your wand/hose assembly is blocked. Try following the blockage procedure in your user guide or visit our website's support section where you can use our self help guide to diagnose problems.
www.dyson.com
Kind regards
Darran
Mar 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hose is not getting any suction
when vacuums shut off randomly it usually means they are overheating. this can be caused by a clog somewhere in the line of suction, or, perhaps due to a very dirty filter - either way, the motor is working hard and getting too hot.
try removing all the various tubes and parts along the suction route and checking for clogs (a flashlight might help too). also, have you rinsed out your two pre-filters lately as recommended in the Dyson manual? it might help.
Apr 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oct 27, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
61 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
