Question about Panasonic Televison & Video
No power on my TV
I was turning on the tv but it didn't came on, like if there was no power on it
  • 261 Answers
If there is no power at all, it might be your power supply, g o to discountdashmerchantdotcom and call them, they'll troubleshoot you for free, it's totally worth it.
Posted on Jul 23, 2009
I have a 46 inch 1080 P Toshiba TV the green light came on the TV didn't come on then the green light didn't come on anymore what could be the problem I had the TV for a month today
If set is new and only a month old have it repaired under warranty. If no light for power at all now I need to know the model number to give suggestions as to what is wrong.
Apr 22, 2012 | Toshiba Televison & Video
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Need code list
You didn't provide your TV brand so PowerScan1.Turn the TV on2.Press and hold the TV POWER button for three seconds - The LED shouldflash3.Press the TV POWER button 4. Press the UP orDOWN arrow buttons on the remote (about one press per second). Stopas soon as the device turns off. -The TV should turn off5.Press # - Now addressed
Dec 19, 2011 | Televison & Video
I have a LG tv 37 inch LCD and the green light is bliking and the TV does not turn on. What should I do
Hello jmgarcia1128,
Welcome, and thank you for using FixYa!
To answer your question: This TV will need to be taken to a local TV Repair Shop for diagnostics of the Main Board.
The TV is receiving power, but can't start (post) to give you display and audio. I would have included a link for you to see the board, and perhaps purchase it, for the repair; however you didn't list the model of the TV.
If you go on to eBay! and plug in the model number followed by the word "power board", you will see the part you need, and the price.
Have a great evening!
Sep 13, 2011 | Televison & Video
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
I have a 42inch sharp aquos LCD tv and there is no power. The power button keeps blinking. There is no picture and sound. What is the fix to this problem.
Power problem are cause by many reasons, i.e Power supply circuit, Lamp driver circuit and most often the TV detects an error cause by power surges. To protect TV from further damage most LCD TV have protection circuit built internally. If this is the reason of your LCD TV not powering On, an error data must be reset back to zero.
To change data you will need to access the service mode and change the value of lamp error code to zero (0). Entering service mode requires a trained TV technician. Changing data can cause more problem to your television. If you are not qualified to service your television, please do not go to service menu codes. Moreover below are the process, pls do so at your own risk.
* Unplug the TV * Press and hold the {VOL -} + {CH+} buttons located on LCD TV unit (not in remote control) Note: If above didn't work, alternately use (VOL -) + (TV/AV input) buttons located on LCD TV unit (not in remote control) * While holding the above buttons, plug in the TV. * The TV will turn on with the "K" or "K123" appears om screen. * Use {CH+} {CH -} buttons to go and display the service menu. Note: If above didn't work, alternately use (VOL -) + (CH -) buttons. * Search for "LAMP ERROR menu" from the displayed service menu by using "up or Down cursor" from remote control, or alternatively use "CH - or CH+ to select "LAMP ERROR" * change it to zero (0) value, using {VOL+} or (VOL -) on remote control. * Turn the set off to exit the Service Menu.
Jul 03, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Have older rca tv...shut off with sleep mode...will not turn back on...tried unplugging...didn't work...now cannot get it to turn on
Try to open the back cover of your TV.Then check the fuse of your TV near the out let cord of your tv.check if the fuse is blowned or open.Replace new fuse with the same ampere.Then power on again the tv.
Jul 01, 2011 | Televison & Video
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
