Question about Watts Onan Portable Generator - 4000 , Model# 5500
I have aonan marquis gold 5.5hgjab on my rv it starts run the first time for 15 to 20 min then stop then will not prim or start for 5 or 10 min like it cool off then restarts run for 5 min then stop the code 36
    Problem Solver:
  • 3 Answers
MINE AND A FRIEND OF MINE HAD THE SAME PROBLEM AND A MECHANIC TOLD HIM THHAT THE FILTER WAS BAD EVEN THOUGH IT LOOKED FINE SAID SOMETHIG ABOUT THE FIBER IN THE FILTER GOES BAD. HE CHANGED HIS RUN FINE SO I CHANGED MINE AND IT SOLVED MY PROBLEM TOO.
Posted on Aug 06, 2012
    Sergeant:
  • 202 Answers
The ignition coil might not be good, have u tried changing the spark plug,
Posted on Jul 24, 2009
I have a 2006 winnabago with onan marquis gold 6500 lp generator that won't start
Check the Onan web site for troubleshooting. Otherwise it's probably time to go to an RV center to have them check it out.http://www.cumminsonanstore.com/
Oct 13, 2014 | Electrical Supplies
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
I have a 6500 lp onan marquis generator in my rv that wont start. any suggestions?
Check the fuel. If old, drain & refill it.
Check for spark.
If the fuel is there and good, trace it to the carburetor. Check the carburetor bowl for fuel.
Check the spark plug, the magneto, any switch that breaks the circuit or kills the circuit for spark.
If you're getting good fuel to the carburetor and you're getting good spark, try to start it with ether spray.
You might also want to check compression while you're checking everything else.
Jul 26, 2014 | Onan Marquis Gold 6500 Lp
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
10 min. run time
Sounds like the vetilation hole in the gas cap is plugged, so fuel feeding out pulls a slight vaccuum in the tank. Flow stops until some air leaks in. Clean the cap or leave it loose.
Dec 02, 2017 | Garden
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
My rv compressor will run for about 5 to 10 min and then the compressor will shut off "fan will continue to run because the temp is not cool enough to shut off" and then the compressor will try...
This is most likey due to a low voltage condition within the site 30 amp hookups are not enough esp if there are a lot of other units in the park. got a generator?
Jul 31, 2011 | Dometic Rooftop RV Air Conditioner
5500 marquie gold startes run for a few nim thin
shut fuel off at tank, pull fuel line off carb ,slowly turn on fuel if fuel flows freely(real good stream)your carb needs replacement(cant buy parts to rebuild EPA) if fuel just barely trickles out . there is a screen in the fuel tank that is probably clogged
Jul 23, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
754 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Jim London
Jim London
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
