Miscellaneous Logo
Kayla Phillips Posted on Mar 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What would 28 width by 48 length be in square feet?
samuel caleb
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 45 Answers
  • Posted on Mar 17, 2017
samuel caleb
Expert
Level 2:
New Friend:
Greenhorn:
Answers
45
Questions
0
Helped
19812
Points
361
Try to be more specific
If width = 28 ft
length =48 ft
Square Footage = 1,344 ft²
Square Yards = 149.33 yd²
Square Meters = 124.86 m²
Acres = 0.03085 acre
for more help visit
Square Footage Calculator
2answers
How to calculate square feet
Assume you have a rectangular area such as a room and, for example, you want to calculate the square footage area for flooring or carpet. The way to calculate a rectangular area is by measuring the length and width of your area then multiplying those two numbers together to get the area in feet squared (ft2).
Square Footage Calculator - Calculator Soup
https://www.calculatorsoup.com/calculators/construction/square-footage-calculator.php.
or try this link.
How to calculate square feet Google Search
Calculate cubic feet of stone wall 120'long x 6'-6" high x 3" thick
your measurements are in different units, say feet and inches, you can first convert those values to feet, then multiply them together to get the square footage of the area. If you are measuring a square or rectangle area, multiply length times width; Length x Width = Area.
2helpful
6000 cubic feet equals how many sq. feet
You can't convert cubic feet to square feet because cubic feet has an extra dimension, you could fit an unlimited number of square feet into cubic feet.
The formula for Cubic feet is:
length × width × height
The formula for Square feet is:
length × width
2answers
How to convert room measurement to square feet?
Measure the length and width of the room (in feet) then just multiply the two numbers to give square feet.
How do I get the square footage of concrete sidewalk
  • Hi Tony: Don't know what this has to do with air conditioners but .......
  • Square footage is the mathematical result when you multiply length by width.
  • Since you're trying to find square feet. the dimensions that you are using must be in feet.
  • Length (feet plus (inches divided by 12))
  • times
  • Width (feet plus (inches divided by 12))
  • equals
  • square Feet.
  • Any questions or numbers for your project? Just reply as a comment to this post.
  • Cheers
How many square feet of floor do I need if it's 9.3 feet one way and 11.7 feet the other way
Good morning Lisa!
There are likely two or three answers here.
Multiplying out directly, you get 9.3 x 11.7 = 108.81 sq feet.
But, the only floor covering that goes down like that is paint.
If you are putting down 12x12" tile, then you'll need to go 10 wide in the 9.3 foot direction (with cut tiles for the last .3 foot), and 12 long in the 11.7 direction, so you'll need 120 x one square foot tiles.
If it's tile of another dimension, divide the dimension into the 9.3 and into the 11.7, then round the answer up to the next whole number for each, and multiply together. 2x2 foot tiles would go 4->5 times for 9.3, and 5->6 times for 11.7, to give you 5x6=30 tiles x 4sq ft/tile = 120 sq feet.
If you're doing wooden flooring, you'll do a similar calculation based on the width of the wood laths, divided into one dimension and rounded up, times the linear feet needed in the other direction. If the boards are 4 inches wide, running parallel to the long wall, 4" goes into 9.3 feet 27 times, so round to 28. 28 x 4" = 9.333 feet You need 11.7 linear feet the other way. 11.7 x 9.333 = 109.2 sq feet. Though you won't likely be cutting 11.7 foot long pieces off of some piece as long as a full tree, so divide the board length into 11.7 and round up. If it comes in 3 foot sections, then 3 goes into 11.7 three times, round up to 4, so you'll have 28 widths x 1/3 foot per width x 12 feet length per strip = 112 sq feet.
Hoping this is helpful. good luck!
1helpful
4answers
2answers
How do I figure square feet?
in a square or rectangular room take the length and width of the room and multiply however if you com up with inches you must reduce fractions for example 6" inches is .5 feet
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_66344e9ad974c715
1helpful
What is 25 linear feet in square feet
That depends on the length and width.
24 feet 11 inches by 1 inch is about 2.01 square feet.
24 feet by 1 feet is 25 square feet.
20 feet by 5 feet is 100 square feet.
12.5 feet by 12.5 feet is 156.25 square feet.
Paul thinks his garage is 28 feet by 32 feet and is within 1 foot of the length and width. What would be the range of the garages area?
28' x 32' = Area 28 x 32 = 896 square feet. 27 x 31 = 837 29 x 33 = 957 27 x 33 = 891 29 x 31 = 899 28 x33 = 28 x 32= 28 x 31 = 27 x 32 = 29 x 32 =
so the factors are 27, 28, 29. 31, 32, 33.
and so on....... all combinations of those above measurements.
Top Miscellaneous Experts
jws1013
Sulejman Sulejmani
Sulejman Sulejmani
Accurate TV Repair...
Are you a Miscellaneous Expert? Answer questions, earn points and help others
