Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Air wont built in tank, motor runs fine
I have the craftsman 3 lb tank and I took the cover off and the reeds are fine. They are not broke and the tank still wont built air. any other thoughts?
  • 520 Answers
As the pump is running try spraying all the fittings with soapy water and look for bubbles. Hope this helps. Good luck.
Posted on Jul 23, 2009
  • 3 Answers
Do you hear any air pressure coming from the unit at all? if so where?
Posted on Jul 25, 2009
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Sources of noise from craftsman oil free compressors (could be Made by Campbell Hausfeld or Porter Cable) include loose fan, failing bearing/s on the piston rod and housing, failing seal ring on piston, air filter intake and loose motor mounts. With the housing cover off, check the fan blade for cracks or loose screw. Turn motor by hand till the piston is at top of stroke. Examine the cylinder for scratches close to top. If scratched, air is leaking past vinyl ring making noise and causing longer fill time. If everything looks ok, suspect noise coming from bearings. Hard to tell if bearings are failing by looking at them. I have seen many failures of the piston bearing on the crank (fairly easy to change, I use alternator bearing from auto parts ) , however, the bearing in the housing just behind the crank bearing is much harder to replacable. Good luck with your fix-it project.
Jun 11, 2012 | Craftsman Air Tools & Compressors
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
Will only build air to 35 lb .keeps running but no air above 35lb
Most likely it is a leaking valve. If ether the intake or exhaust valve, but not both, leak back pressure will be low. These small compressors usually use reed valves. Try and remove the head, and check that the reeds are not bent up, and that the seat it seals against is not cut. If the reads are bent you can sometimes flip them over. You may be able to get new reads from Sears if they are bent or broken.
May 07, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Compressor will run, but only builds to 20 lb pressure. Line to tank gets hot.
Very hot air is an indication of leaking /broken head gasket or reed valve. Before you remove any parts, with compressor running, check all fittings for leaks with soapy water. If no leaks, remove head and examine parts. If reed valve is broken replace as needed or do creative repair. Some valve plates have multiple reeds and only one reed is broken. Depending on your skill level, you can thread the hole and seal with piece of bolt (finished repair must not be any thicker than the plate). Good luck
Jan 29, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
Wont build pressure past 60 psi
If you have oil-less type of compressor you may be leaking pressure past cylinder/piston ring or just air leak. Easy to check. Spray soapy water on all connections, first with pressure in tank and motor shut off, then once again with motor running/pumping. Repair as needed. If no leaks remove cover to motor and move piston to top of cylinder and examine condition. If you see scratches neer top of cylinder, then pressure is leaking past vinyl ring. If cylinder looks shiny and smooth and piston vinyl seal looks intact, suspect problem with reed valves or head gaskets. Parts are avilable at sears parts on the web. Good holidays expensive.
Dec 14, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
3gal craftsman horizontal compressor wont build pressure
Without knowing specifics of your unit, If there are three reeds, then two are probably for intake and one for exhaust. Intake reeds should be on the piston side of the valve plate, discharge reed should be on the head side.
There should be a divider in the head side to separate the inlet from the discharge. Make sure the valve plate is turned so that the air from the air filter side goes to the side with the intake valves, and the air from the discharge valve should go to the side with the pipe to the tank.
Oct 21, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Motor run for ever but tank does not fill up with air.
Sounds like you broke a valve. You could take apart the head assembly and check the reed valves but I would check to see if parts are available before you do this. Craftsman compressors are not the easiest compressors to find parts for.
Mar 31, 2009 | Craftsman Air Tools & Compressors
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
231 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
