Question about Xerox DocuPrint N2825 Laser Printer
I have a paper jam and need to fix it. I took out a piece of paper alreay,but the printer still thinks that there is a paper jam.
    President:
  • 1,996 Answers
Here's a list of the various paper jam errors and solutions for your N2825 printer. You can also access or download the online pdf manual for your printer here, and by scrolling to the troubleshooting>paper jam section see a list of instructions for resolving these errors.
If that doesn't seem to help, you may want to go to the home support page for your printer here and use the guides to help find a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
My printer says paper jam but i see no paper jam
There might be paper jammed internally or the spool might just be stuck. On the back of your printer should be a removable panel(it may be on the bottom depending on you make and model). After removing the panel if no pape jamer is visible try rotating the spool and reconnecting.
Jun 15, 2011 | HP OfficeJet 4215 All-In-One InkJet...
It is still paper jam. we alreay clean everything
If you have already removed the paper from the printer, and there is no longer any jammed paper in the machinery, try turning the printer off for 10-15 seconds and then turning it back on.
Mar 03, 2011 | HP Officejet Pro 850 InkJet Printer
The printer keeps saying there is a paper jam and there isn't. clearing path, or turning off power had no consequence
I have seen these printers pick up on a tiny piece of paper stuck in a place almost impossible to see. Carefully look at the entire pape path and you will probably find a tiny scrap of paper stuck in a blind spot.
It aso can be one of the paper path limit switches has become jammed and need to be re-aligned. That is much harder to do, and honestly, you can buy several new printers for the cost of that repair.
Jun 27, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
Paper jam won't clear
Check the far left side under the cover..Typically they have a photo sensor for cartridge positioning and if any pape gets jammed on the left side t will behave irratically.
May 07, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Frequent paper jam
Where is it jamming?
In the feed tray, along the paper path, in the imaging unit or at the exit/finsiher?
The first thing is to be 100% SURE you are entering the paper settings correctly.
Jun 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
hey, give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Oct 19, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Aug 23, 2007 | Lexmark Optra T610 Laser Printer
Jamming
Hi Scott, My experience is if there was a jam and it still says it's jammed after clearing the paper you missed some. Even if the sheet that caused the last jam didn't tear it may have moved a torn piece of paper that was in there from before. Check again, really well for small pieces of paper stuck somewhere. Hope that helps. If not let me know and I'll see what else we can do. El Duderino
Nov 16, 2006 | Canon PIXMA MP150 All-In-One InkJet...
Xerox DocuPrint N2825 Laser Printer Logo
78 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
