Question about Dell Inspiron 6400 Notebook
An E1505 went dead after water spilt on it
Have disassembled it and dried it out throughly. When attempting to turn it on, three green lights under the display come on for about 5-10 seconds, then go off. How can a person troublshoot to determine what assy. needs to be replaced? Any schematics available?
  • 1 more comment
  • donbart Nov 21, 2007
    Haven't tried the suggestions yet, but the best info I have received so far after three days of asking questions online. Will give feedback after I try the suggestions. Thanks!
  • donbart Nov 25, 2007
    Ron... I did the bare bones thing and it acts the same. I had the adapter, motherboard, 1 stick of memory and the display hooked up. Doesn't it need the HD also? The fan doesn't run and the display doesn't show any indication of florescence backlighting.
    Previously I had checked for the 5v at the video connector and there wasn't any. Wish I could get hold of enough of a diagram to check the MB power supplies. I'm experienced at troubleshooting PCBs if I have some data, but, I'm not going to do it by the seat-of-my-pants, ha. Thank you for listening. donbart.
  • donbart Nov 29, 2007
    Where did my last Post go?
    OK, I'll re-post it,
    Ron, after reading your first solution it gave me the courage to 'get into' it. First I went through the "bare bones" approach and it acted the same way (three green LEDs on, then off in about ten seconds). So I let it lay for a couple of days before putting it all bac together to give it back to my grand-daughter with the bad news. After reassembly I thought it would be a good idea to try it again. IT'S WORKING! I think RESEATING must have done it. Some contact(s) must have been wiped clean. ITS A FIXYA!!
  • 324 Answers
Good morning donbart,
Sounds like you probably did in the motherboard. They have a number of surface mounted fuses that are not easily replaced without specialized tools and training.
However, before we jump to that conclusion, there are two things that we can try. (Remove the battery and don't replace it until you are done with these processes) Reseat everything, or take it down to "bare bones" and see what happens.
Reseating everything means to tear it down to the point that you can access every connector and removable component. Disconnect each cable, and component, one at a time and plug it back in. While you're doing this, check for water stains (mineral deposits) and gently clean them with alcohol if any are found. If it doesn't come up after doing this, try the bare bones approach.
By bare bones, I mean to disassemble to the point that you only have the a/c adapter, motherboard, 1 stick of memory and the display hooked up. At this point, if it doesn't come up farther than it does at present, you more than likely have a bad motherboard.
If it does show signs of life, start reconnecting one item at a time, and try to power up after replacing each item or connector. If you replace/reconnect something and it no longer does anything, you have just located the part that is bringing your system down.
Using this approach, I have seen memory cards, hard disk drives, keyboards, mice, touchpads, floppies, cd readers all cause this type of problem.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Posted on Nov 21, 2007
  • 1 more comment
  • Ron Roske Nov 21, 2007
    Will be waiting to see how this comes out. Like I said, If you have any questions...
  • Ron Roske Nov 25, 2007
    Well, nuts! For bare bones, you don't need the HDD. It should come up with something on the display in bare bones. If not, your motherboard has shot craps. ;o(
    It does sound like a power problem but like you noted, they insist on building the ps on the motherboard.
    Diagrams and/or schematics are non-existant as far as I can see. It's hard to even get your hands on a motherboard parts location layout anymore.
    One idea that you may want to try is to look at the board real closely. They have been using surface mount fuses on them. I say to look real close because there are several different styles and a lot of them look the same as the caps and resistors. No marking on most of them. You have to get your clues by reading the markings on the board, itself. If you can find them, you might apply power and check for voltage on each end of any that you can find. If you find one blown you might be able to solder a new one on top of it? Trying to find a replacement may be an interesting project in itself.
    Don't know if that'll do it for you but it might be worth a shot.
  • Ron Roske Nov 29, 2007
    Good 'nuff! Am always happy to help someone. Am glad to see that you got it fixed, and thanks for the "FixYa"!
    Thanks again!
Can my calculator be fixed if water was spilt on it ??
Turn it off and do not plug it in back in the AC . Get a screw driver disassemble it completely and dry it well. Cross fingers to work back again
Jun 24, 2014 | Sharp EL-1197P Calculator
Can my calculator be fixed if water has been spilt on it??
Trey taking it apart and drying it. Use cans of compressed air , if necessary. Put it out in the sun, all day, to dry. If this does not work,
something got fried. These procedures need to be done BEFORE turning it back on.
Spilt water on keyboard acer aspire 5542, while it was turned on, some keys have stopped Working. can this be fixed or does it need replaced?
Before you declare the keyboard dead and unusable please do the following. Use the hairdryer without heat to blow cold air into the keyboard. This will remove all traces of water that may be shorting the keys. Do it for quite sometime as you have to ensure that there is no water left under the keys.
All the best
Mar 25, 2011 | Computers & Internet
Portable dvd play and kid spilt water on it, now the screen is in negative format, how do you fix this?
The main board has been damaged, the water gets into the parts and causes corrosion and oxidizes turning any ic a green color. To attempt a repair the player will need to be unplugged and the battery removed before you dis-assemble the player. When you can see the boards, get some rubbing alcohol and a stiff toothbrush, dip toothbrush in the alcohol and scrub each part carefully removing any green on the boards and parts. After you finish let it dry overnight, and inspect the boards to see if any traces remain. If everything checks, assemble it back together and try the player.
Jan 26, 2011 | LG DVP7772 Portable DVD Player with Screen
Dropped my tocco f480 in water now i have a green screen and won't turn of
First, remove the battery from the phone and put the phone and the battery under the sun. The back of the phone must face towards the sun light.
Try it for three days and let the phone dry up. If the same problem occur, then there are components that went bad and you need to contact the manufacturer for repair.
Good luck and have a great day!
Feb 07, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Spilt coffee on calculator and now the divide sign doesnt work
Remove the batteries and then you can attempt to clean the key button by spraying it with electronic contact cleaner. However, be very careful to only use a small amount to get around and under the key, as the contact cleaner could damage the key material.
If possible, you should try to disassemble the shell and clean off the keypad with a damp towel (water only) so as not to remove the conductive pads on the underside of the keypad button.
You can also try to use a slightly dampened cloth to get the contamination under the keypad, without disasembling the calculator, but you'll have to wait for a good 24 hours before putting the batteries back in to see if it worked. You really don't want any water residue in there to cause more problems, hence the reason I usually disassemble things and use a contact cleaner to tackle the problem.
Allow the pad to dry before reassembling and you should be back in working order.
You can get the contact cleaner at any RadioShack store.
Hope you find this Very Helpful and best regards!
Aug 19, 2009 | HP 12c Calculator
Spilt water on my computer
take to the near by technician with experience in electronics and IT
May 25, 2009 | HP Pavilion dv8000 Notebook
My Samsung YP-U3 MP3 player went through the wash, help!
Have the unit be dry. If you can get a disassembly manual it better to dry the unit disassemble. But a high probability its battery is a goner.
The moment its get wet, you shouldn't try to switch it on, that could be disastrous to the unit. Let the unit still off or be off.
If your lucky after it is dry it will start. But as I've said battery could be dead or the unit is also get damage. Even only the battery is damaged, replacement could be hard to find.
So try to let it dry before opening it.
May 13, 2009 | Samsung YP-U3 MP3 Player
Within an Hour my SpotBot stopped working
Some of that water must have gotten inside amd shorted something. If this is less then 1 year, it would be under warranty. It iwll have to be taken apart and checked.
Dec 02, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Acer Aspire 3000, Hard Drive Problem
the coffee is somehow conducting a short circuit across solder pads, where it should not. The solution lies in removing the coffee. Disassemble completely to the point where you can take the main board and hard drive connector (if exist) out and actually wash in a tub of soapy water and rinse in a tub of alcohol and towel dry and then lightly blow dry. During disassembly, video your work to play back at a later time.
Jun 09, 2007 | Acer Aspire 3000 Notebook
Dell Inspiron 6400 Notebook Logo
911 people viewed this question
Alun Cox
