Question about Kenmore Refrigerators
Why is my refrigerator really hot in the middle
  • Kenmore Master
  • 3,361 Answers
That is normal. The condensate heater is on to prevent moisture from forming between the freezer and fresh food sections. It may get up to 120 degrees.
Posted on Jul 23, 2009
2 Suggested Answers
  • 193 Answers
SOURCE: side of refrigerator getting really hot from top
The unit has a auto defrost feature. Every six to eight hours these heaters come on to melt ice build up.The cabinet will feel warm to the touch during this cycle.If it is always hot, I suspect a stuck defrost thermostat
Posted on Nov 14, 2009
Hi is it normal that the middle Paleo that the doors close onto seems really hot? We have an American style fridge freezer, everything else seems ok, but I have never noticed it before!! Thank you
Again a similar post as my last. This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | Refrigerators
Middle section divider gets real hot
Any heat inside a refrigerator is a not so good thing, firstly you have to assertain if the thing is in defrost or not, they do this regularly to defrost the ice, if it's hot all the time then you have a problem.
Nov 25, 2013 | Admiral 26 cu. ft. Side-By-Side...
The middle panel between the freezer and refrigerator is very HOT
Sounds like the door heater has gone bad. You will need to pull off both the fridge and the freezer door panels and see which heating element has gone bad. This heater is to make sure that your doors do not ice up. But once they go bad they can be a pain to replace and repair.
Jan 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
Side of refrigerator getting really hot from top to bottom on freezer side about 1 inch from the door back. Also where the two doors meet in the middle, really hot. What can I do?
Nov 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge is getting super hot
These fridges are designed that way believe it or not. Designed to eliminate condensation on surface but in hot weather they get really hot then stay warm until compressors cooldown. I would not worry.You can also call kenmore sears and they can tell you if it is fine.
Aug 12, 2009 | Kenmore Refrigerators
Roper center divider hot
Either a bad condensor fan motor ( fan which cools the compressor ) OR dirty coils . Remove the kickplate and vacuum .
Aug 02, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
What is causing my refrigerator to run warm...its a side by side and the middle area between the doors gets hot at times...the inner temperature of the refridgerator part doesnt cool down as much as it...
The outerside of the refrigerator is always warm due to the PUF insulation material being used currently. So the middle area should get little more hot, comparative to the sides. However if you are facing cooling problems, for now turn the thermostat a bit lower also check if the water draim pipes are clear. If it really struggles to keep it cool have tha amount of refrigerant gas checked to see whether its full or not..............................sodeep
Jun 22, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Whirlpool refrigerator side by side door seal very hot
when you said fans working....does it include the condenser fan? or it may have two evaporator fans..
if condenser fan is working, then it is just normal. if the compressor is running, that part would really heat up. and if it is too hot, then the condenser fan could probably not running.
its not constant because the compressor cuts off when ever the thermostat cuts off.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Whirlpool GC5SHEXNS Side by Side...
Outside middle devider hot
It should be warm but not hot. If it is too hot then either the condensor coils underneath are too dirty or the condensor fan motor has failed.
Nov 12, 2007 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
