Computer wont boot have steady amber light on the start push button nothing on monitor
  • 6,784 Answers
The Power Supply takes AC current and converts it to various DC voltages. If the power supply fails to deliver consistent and precise voltage to the components of the PC, the system can become unstable or can be damaged. You can confirm power supply issue by listening to the power supply cooling fan. it should run when you push the power button. if it is not, this will confirm a power supply issue and, it should be replaced. Ok, if the power supply fan is running and, the Unit fails to present a visible picture on the screen, the can be a video issue as well. You will need to confirm that the monitor has power. Also, check the connections to the video card(A/V,DVI cables). If everything is well there, move on to the video card itself. Unplug the PC and make sure the graphics card is securely and properly installed into it's slot. Check that no pins are bent or missing from the connector.
Ok, if all the above check out ok and, the monitor has power, this will confirm a major issue concerning the Mother board. have it replaced asap, if possible. it has failed.
Posted on Jul 23, 2009
  • 184 Answers
Check you power cable and extension socket for steady power supply. if it is ok, consider plugging it into another outlet. if that fails, check your memory card. if you have more than one card installed, consider taking one out and restarting with one. if it fails, swap it with othe on and the othe out. if it fdails, take out the C-MOS battery from the motherboard and replace it after 2 or more minutes. restart the system.
Computer turns on won't boot fan runs fast
Are you getting any video display before the amber light goes off?
Aug 16, 2014 | HP Compaq Presario SR1830NX PC Desktop
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Monitor stuck in power save mode
This might be problem with your with your monitor or videocard.
Click Here to Troubleshoot.
Thanks, PREM
Mar 31, 2009 | Dell Dimension E520 PC Desktop
Does the computer turn on all the way now or does it start to boot and then turn off?
Your Power Supply is no good, you are going to have to get it replaced. Once you get it replaced everything should be fine.
Jan 02, 2009 | Dell Dimension B110 PC Desktop
Dell Dimension 4600 Won't Boot Up, Steady Amber Light is on tower
I have seen with some of the small form factor dell's that there can be a motherboard problem; my expirence with the regular towers and the steady amber light have been power supplies. I have a dimension 9100 that is three years old now and I am on my fourth power supply. I am not sure that you would have one laying around, but in my past expirence its been teh power supply. On the ones that I have seen where it was the motherboard you could clearly see on the chipset where it was damaged from heat (it was burnt). Hope that helps
Nov 19, 2008 | Dell Dimension 4600 PC Desktop
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
