Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore mdl 665.16034401 dishwasher
the green "clean" light on my dishwasher is blinking. There is no water in the bottom, and cancel doesn't help. Sears won't help me without sending out a service tech. I believe I just need to know how to reset it. It's hard-wired, I believe, so would have to pull it out to unplug it. My grandkids have been here and I think that they may have pushed my buttons. Can you help me with reset button codes? thanks, jeanne
  • 6 more comments
  • bearzie Nov 21, 2007
    can we try something else?
    Smart Wash/ Pots-Pans / Normal Wash / China-Gentle / quick Rinse / Hi Temp Wash / Sani Rinse / Heated Dry (lock on) / Delay-hours / Cancel-Drain / Start-resume
    :-) thanks for your patience
    SWEET !!! YOU'RE A GENIUS !!! that seems to be working , at least there is water and it's running! If it doesn't dry, then I guess I will have to get a technician out? I think I owe you more $$. Thanks again!!
  • gretchie Jan 04, 2008
    Hi, I am having the exact same problem with the clean light blinking. I have the same model number 66516033401 Kenmore (only 2 1/2 yrs old). i have tried resetting the machine by pressing sani-rinse and heated dry several times. It seems to be running now. YEA!!! I just hope it continues. I had a repair guy out and he wanted to charge me $275 to replace the control panel. THANK YOU for your help!!!
  • wihos Apr 07, 2008
    My clean light flashes 7 times than pauses, and flash again. Sear would not help. What should I do?
  • Anonymous Apr 16, 2008
    I had the same issue w/ the clena light blinking 7 times and nothing else working....pressed the sani rinse and heated dry buttons several times, and it reset just like it said to do on here...THANK YOU!!!
  • lanosnhoj Apr 25, 2008
    tested heater element with vmeter ok. tested heat sensor seems to be ok. tested door switch ok. Can not find wiring diagram. All lights on control panel come on when individual button pushed but clean light always comes on and flashes and nothing happens.
Do you have the code for a 665.13783k601
The sanatize cycle no longer works. Sears said that warranty is not valid as we purchased from sears outlet and did not get them to install- i know this is bs...
Posted on Mar 10, 2008
  • 213 Answers
Looking at your control panel there should be a option/clear button. push that button then the button to the right of that button back and forth untill all lights light up. that will start a test mode just let the test mode run once its done you should be able to run the dishwasher again
Posted on Nov 21, 2007
  • 2 more comments
  • chris hooper Nov 21, 2007
    whats the model number of your dishwasher? open the door the number is on a sticker on the left just inside the dishwasher
    ok the diagram isnt showing your button. in order, what do your buttons say from left to right. each model is differant so i need the line up of your buttons
    press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
    your welcome
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
does your panel have a lock button on it? if so press and hold button for 5 sec to try to unlock if not post your model number so i can give you the sequence
Nov 21, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Flashing or blinking green clean light 7 times?
This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light 7 times.
The failure can be wide ranging here are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Here is a link for instructions on sump clean out
Poor cleaning or noisy Whirlpool KitchenAid or Kenmore
General Dishwasher washability
White powder hard water calcium residue
on Apr 25, 2010 | Maytag MDB8959AW Builtin Dishwasher
Green clean dishes light blinking instead not blinking. Dishes clean, but not totally dry. I removed them from dishwasher. Clean green light continues to blink after door is shut. Pushing cancel...
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Aug 04, 2011 | Kenmore Dishwashers
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
May 18, 2011 | Kenmore Dishwashers
The green clean light is flashing. It will not go off even when we press cancel. The wash cycle was not completed. The model # is 665.17283400.
The green clean light means that your dishwasher isn't heating the water. Go to the link below to see how to reset the error code and check for reasons that the error happened.
Good luck
Mar 05, 2011 | Kenmore Dishwashers
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
press heated dry again
press normal wash again
wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore 665. dishwasher blinking "clean" light
kenmore lite blinks on quick rinse, seems to be stuck on that.
Aug 08, 2008 | Kenmore 15129 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
534 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
