Question about Frigidaire ATF6000ES Front Load Washer
The belt on my friends frigidaire front loading washing machine keeps falling off. the drive pulley has ridges on it and the driven pulley is smooth. the belt stays on for 2-3 small loads then falls off. what is your advice>
  • Frigidaire Master
  • 3,361 Answers
The belt has stretched out it must be replaced.
Posted on Jul 23, 2009
Front loader hums instead of starting
Try to get ahold of a qualified service technician that specializes in washing machines and dryers.
My guess is it could either be if its belt driven the belt has broke and the drive motor is turning freely or the drive motor is possibly burnt out or in need of replacement.
Its not much but I hope it helps
Sep 27, 2013 | Frigidaire Affinity ATF7000ES Front Load...
Washer belt keeps coming off
This issue is likely due to misalignment between the driving and driven pulleys. This misalignment can occur if one of the pulleys is loose on its shaft. You may be able to inspect the alignment to see if such a misalignment exists.
Another possibility is that your machine may have a belt tensioning idler. If so, it could be misaligned, worn out (does not rotate smoothly when the load is removed from it) or have loose mounting screws.
You will need to spend some time watching the belt while the machine is running in order to evaluate conditions at the time of failure.
Keep hands and loose clothing out of harms way.
Apr 13, 2013 | Washing Machines
I am having problems with my front loader washer. The belt keeps coming off.
Check the pulley If is loose tighten the pulley If it is making oblong shapes you need to replace the pulley
Jul 12, 2011 | Frigidaire ATF6000ES Front Load Washer
I may have overloaded my Frigidaire Pin #134465400 0410 front loading washing machine. On the last load it did not complete the spin cycle and there is water laying in the bottom of the drum. When I try...
Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight (looks like a cement quarter round cement block), spider pulley and belt. The counter weight is attached to the top of the drum and can loosen and fall to the bottom damaging the spider pulley. If the counter weight is firmly attached to the top of the washer drum and the belt is attached to the spider pulley and motor, remove the top cover and lower front panel.
With any luck the counter weight knocked the belt off. If you are unlucky the counter weight broke the spider pulley.
Here is a link for parts.
Jan 06, 2011 | Washing Machines
Does the kenmore elite he4 washer belt go on with the ridges up or down
The ribbed side of the belt is placed against the spin basket drive pulley. The ridges are required to go to the inside in order to fit properly on the drive motor shaft. The following link explains how to properly install a drive belt on one of these front load washing machines:
http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Jun 30, 2010 | Kenmore Elite HE4 Electric Dryer
Washes fine. However, belt comes off in cspin
If it is a toothed cog on motor you need to make sure its on okay,also if the drum pulley is loose or bearings gone/noisy this will cause it to fall off.
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Belt won't stay on.
When you fit the belt, try turning the drum by hand,
Does it come off after a number of revolutions, if yes, you`ll probably find that the bearing in the motor or drum has failed allowing the shaft to move meaning that the pulley isn`t in line with the drum. New motor or bearing required. If it stays on when you manually turn it, does it flick off when the motor starts, if so, make sure that you`ve got the right belt, If it`s the wrong size, it will slip when the motor starts allowing the belt to move sidewards, hence slipping off the drum pulley wheel. Ian
Aug 04, 2009 | Frigidaire ATF6000ES Front Load Washer
New belt runs too close to drum on pully
adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Dec 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
245 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
