SOURCE: AVR 1508 Reciever Setup Issue
AVR 1508 doesn't upconvert. Only components coming in on HDMI will go out HDMI.
SOURCE: HDMI output from AVR-4806
You say your connected from the DVD to the Denon with an HDMI cord and the Denon to the TV with an HDMI cord and you get no DVD video? can you get the Denon setup menu? if so change the res. output on the DVD to 480p, 720p or 1080i but not 1080p
SOURCE: no video/display on TV when using sony str dh 500
If your set up is HDR-AVR and TV all you need to do is go HDMI out from HDR to HDMI in(Sat.) of AVR and monitor out HDMI (or composite video) to TV. and select the Sat. input on the AVR. The sound is only comming from the HDR in this case and the composite video or HD video is being switched out to the TV when you select Sat. on your AVR
SOURCE: NAD T747 Shutting Down
get a fan or do a re-stack...open the back of the e-center, Yes it will do a thermal shutdown... just like 3 mile island
SOURCE: How can I reset my NAD T747 to factory defaults?
Restoring your T 747 to its factory defaults: At FM mode, press and hold front panel’s LISTENING MODE button until the VFD shows “Factory Reset”.
Cheers!
