Question about Air Tools & Compressors
Kobalt air compressor won't run
Same as the other guy - my 10 gallon Kobalt compressor model VLK1581009 shows 0 psi on digital readout, but won't kick on.
Guy at LOWES was worthless. Can't find a KOBALT Support number. The 866 307 4104 number on the tank is ''not a working no.''
  • RM432 May 11, 2010
    Does the compressor turn? what are the circumstances? IE Are you trying to start it outdoors or with an extension cord?
    New Friend:
Thanks for the help will ck.these thing out. get back later to let ya'll know .
Posted on Nov 21, 2014
    New Friend:
    Problem Solver:
  • 7 Answers
Under the top cover, under the motor shroud is inline fuse..looks like a car fuse, flat but with pointed ends, replace and the motor will run
Posted on Jan 08, 2013
    President:
  • 1,167 Answers
Hi mate take the head off and inspect the valves and gaskets i had this problem and it was the gaskets gone just make sure the valves are opening and closing ok good luck
Posted on Aug 08, 2009
What kind of oil for kobalt 221565 60 gallon
ordinary engine oil 10/30 or 16 oz synthetic oil ( lowes)
There are compressor oils on the market but as the most it has to do is lubricate the bearings and cylinders , engine oil is quite sufficient to do the job as it has all the additives needed to reduce wear , rust and inhibit moisture from the air compression
if it runs 12 hours a day 7 days a week then there will be a service schedule that you should be aware of but if it is just a home operation then every year or two would be adequate for a service
Jan 09, 2016 | Air Tools & Compressors
Hello I have a 20 gallon kobalt model 033204. I just replase pressure switch but does same thing. When I tur on the compressor jus build 50 psi and shuts off.
This usually occurs when the motors internal thermal / amp breaker opens due to overload or weak breaker. Use an amp gauge to test for too much amp draw. If amp draw is normal, then problem could be the in-tank check valve leaking pressure back to the pump overloading the system, or weak capacitor or weak breaker. Bypass the breaker temporarily if the amp draw is normal to test system. Good luck
Oct 31, 2015 | Psi Air Tools & Compressors
My kobalt 80 gallon air compressor won't turn on
BE CAREFUL! Jump the pressure switch and see if it starts. If so, replace the switch. If it doesn't start but hums, cut the power and try to turn the compressor by hand. Free it up if possible. If it does not hum, look for a reset on the motor or a blown fuse or breaker.
Dec 14, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
Oil capacity of kobalt 80 gal air compressor
You could do a little searching on the web, and answer your own question. You can buy a manual for $4.95 at:
http://www.needanownersmanual.com/product_info.php?cPath=21_30&products_id=549&osCsid=tks6fj36b6skq8h7m155hh8kb1
But worse, you don't even need an answer to this question. Simply add oil until level is about half-way up the sight glass. And don't overfill. How simple is that?
Feb 08, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
On my kobalt digital air compressor i have 150
This was a poor design for kobalt with digital readouts.. The compressor waqs made by several comanies including campbell hausfield and porter cable, But some were imported.
There under the controls is a switch that cuts out the motor, It looks like an oil pressure switch on older cars. There is also a manifold tree that holds the guages and the regulator. There will also be a circuit board that holds the electronics for the regulator control.
Remember you have to set a value to bring up the pressure and the board senses the tank pressure and "Bleeds" off via a solenoid to hold the pressure. The ticking sound you hear is the solenoid, ITs not repair/replacable.. its part of the controls.
If the unit is under warranty you might eant to ask lowes who is their off site repair center, or ask is it available to be exchanged.
Personally, and professionally.. this model is oiless, so it has a shorter life as to being reliable compared to oil lubrication. For the extra bucks you will come out with a more reliable and easier to service model.
Nov 18, 2009 | Air Tools & Compressors
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Kobalt air compressor problem plastic tube gets a hole
EVERYONE WANTS TO MAKE EVERYTHING PLASTIC THESE DAYS. REMOVE PLASTIC LINE AND REPLACE WITH 1/4" FLEXIBLE COPPER ( ANY KIND ) JUST PICKUP A SMALL ROLL AT A HARDWARE STORE. MAKE SURE YOU GET A COUPLE OF FITTINGS, NUTS AND/OR FERRELS. HOPE THIS HELPS, JODY
Apr 20, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
1,995 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
