Staples jammed.How can I unjam and open it?
Hi Alan:
You don't specify what make it is, or if it is powered.
If air, disconnect from supply, remove any staples from magazine, and attempt to discharge.
There will be allen head screws holding the firing mechanism assembly together. Always treat it as if it could discharge.
Carefully loosen the screws and try to remove the jammed staples with a small screwdriver. You may need to actually dis-assemble it to get it unjammed.
Clean parts, oil, and re-assemble.
Should be fine.
