Question about HP Office Equipment & Supplies
I have been using the less expensive replacement cartridges and they even worked for a while then out of the blue the printer said it was not a authentic HP cartridge and stopped printing...any ideas? It's an HP 3740 printer...I run 2 at my desk and one did this then the other about 5 months later.
  • 118 Answers
How much are you saving by using the GENERIC? I will try to find you a good deal on the authentic. Staples tells me it's better for the life of the printer to use authentic cartridges. Are you using Generic or remanufactured?
Daisy
Posted on Jul 23, 2009
Changed black cartridge and now only colour printer will print in is blue/green
The black print head most likely is blocked with dried ink.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 19, 2012 | HP Photosmart 3210 Printer
Samsung CLP 315 invalid toner message
the best thing to do is buy the original toner. how ever if u really can't then try changing the blue colored one
Jul 29, 2017 | Samsung CLP-315 Laser Printer
All color of the canon ip 1980 printer are okay to print... there's no problem to it, but blue is not working... even i have to head clean 10x and deep clean 10x... there is nothing change... the blue ink...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Mar 17, 2011 | Office Equipment & Supplies
Hi, when i try to print from my dell computer, I get half the picture & it comes out in blue. When I run clean cartridge I only get blue lines running across the page. I've checked the ink levels via...
May try new ink jet cartridges, as the nozzles can get plugged up over a period of disuse. Maybe try to wipe the ink jet cartridge nozzles with a cloth soaked with rubbing alcohol to clean.
But, if that doesn't work, then new cartridges are indicated even though they are kind of expensive.
Jan 24, 2011 | Dell 968 All-In-One Printer
I have been purchasing the less expensive ink cartridges (#30 and #31) for my pixma ip1600 and they have worked fine. I just put a #30 in my printer and it won't work. What happened?
Was the replacement cartridge Canon brand on a refill? Either way that style Canon printers are designed to not accept refiled printer cartridges for the 30s, 40s or 50s. It is likely that the printer deemed your cartridge not an un-used original and turned it into an inky paper weight. I would return the cartridge to where ever you purchased it and be sure to only purchase new Canon brand for that machine.
Jan 18, 2010 | Canon PIXMA iP1600 Printer
Black ink does not print even when new cartridge inserted
The printhead is clogged. Some printers have the printheads as part of the ink cartridges. Others are separate. Try taking a swab with alcohol to the head area. If this does not work, try the print head cleaning several times. You may find it less expensive to replace the printer.
Jul 18, 2009 | Office Equipment & Supplies
My printer is malfunctioning. nothing prints
It is likely clogged nozzles in the ink cartridges. Try the nozzle cleaning utility in the Lexmark Solutions Center (installed with the drivers) several times. If it does not correct the problem, but you can get even the faintest lines to print, you will have to replace the cartridges. If it doesn't help at all, you could always try replacing the cartridges anyway.
I know they are expensive. So if it helps, The Fine Print offers refurbished cartridges for a lot less and will even give you a little credit to recycle your used-once cartridges.
Jun 11, 2009 | Lexmark X6170 All-In-One InkJet Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Using non-OEM ink
There are epson ink compatible cartridges in the market that are less expensive but have good quality. Please look for other compatible brands which good quality guaranteed, try those compatible brands which are more popular.
Apr 01, 2008 | Epson (C31C411016) Printer
Lexmark X2350
to be honest, yes it can probably be fixed with correct driver downloads and new cartridge/s etc...however lexmark cartridges do tend to be quite expensive and brand new printers complete with colour and black cartridges are very in-expensive now...you can get them for under £50.....may be best to go for new...and it's guaranteed !
Jan 08, 2008 | Lexmark X2350 All-In-One InkJet Printer
23 people viewed this question
Seeker5211
Seeker5211
