Question about RIM BlackBerry Pearl 8100
My trackball on bb 9000 won't move down
How do i change the trackball on the 9000
  • 21 Answers
Good luck.
if you can get the part -- its a trackball assembly btw not just the ball itself
you press down on the silver ring around the ball and turn, the cover will fall out. use a small probe and lift the assembly out.
many times there's fuzz in there -- check it out before you buy a new assembly
Posted on Jul 23, 2009
  • 70 Answers
What is the symptom with the trackball? Not moving in a certain direction? Usually some vigourous movement of the trackball will dislodge and clean any junk underneath the ball.
Posted on Jul 25, 2009
Blackberry 9630 Trackball not working in the main menu
hold down alt key and swipe roll the ball. for emergency purpose. ferrah.com@gmail.com
Dec 10, 2011 | RIM BlackBerry? Tour 9630 Smartphone
My blackberry 9000 won't scroll down
Hi there. You can replace the trackball on the Bold 9000 by taking the back cover off. You will need to take the battery out and undo a few screws in order to get the back plate off. Once the back plate is off, you can clean the track ball using rubbing alcohol and a Q-Tip. This will help with your scrolling problem. If you aren't comfortable with this, a mobile repair shop will help you. Good luck! Alex
Jul 15, 2011 | Cell Phones
I'm using bold 9000. My trackball suddenly won't go downwards. Up and sides motions are fine. But going down just won't work. It has numb sensation when I try to slide in down, like it is too slide-y. The...
The trackball on these devices can become clogged with dirt, especially if frequently carried in a handbag or pocket. The trackball can be cleaned by yourself if you are prepared to dismantle the phone, and instructions can be found here:
http://www.youtube.com/watch?v=kezDVcUhUe4
Otherwise you may wish to have the phone serviced by a professional.
Jan 17, 2011 | Cell Phones
Trackball from bb bold won't scrool down... What shall I do???
If this is the case, try to reset the phone to factory defaults. If that doesn't solve the problem, you probably have a bad scroll key and this needs to be changed by a cellphone technician.
I hope this helps. Thanks and have a nice day. Merry Christmas.
- HotRatchet
Dec 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
Roller ball of my balackberry 9000 not moving upwards.
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
Oct 25, 2009 | RIM BlackBerry Bold 9000 Smartphone
Trackball gets stuck on BB 8100 Pearl
You can actually pop the trackball out and clean it and the sensors. remove (gently) the silver ring around the ball. if you break it you can buy new ones cheap.. it just snaps in to place. then the ball will fall out and you can take a q-tip and rubbing alcohol and clean it.
Jul 21, 2009 | RIM BlackBerry Pearl 8100
Trackball does not functioning properly
Settings could help some, but I tried that originally with my ball as the first step, and it did nothing. It was definitely the ball that was broken (I frequently use lotion and other products on my hands, and I think that created the buildup.) I would suggest getting a new one to fix that issue, if you can. I got a new blue trackball (go knicks!) at www.blackberrytrackball.com
Jun 17, 2009 | RIM BlackBerry Bold 9000 Smartphone
Trackball want scroll down
Please change the sensitivity, to change the sensitivity follow the below steps
  1. select option in the main menu
  2. select Screen Keyboard
  3. set the horizontal/vertical sensitivity as 100%
May 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve 8310 trackball wont go down
Hi there
I had exactly the same problem. I spent a while trying to use a qtip to flush out the dirt but this didn't work.
I eventually sorted it by carefully lifting the cover (use a credit card to lift it up - slip it in the gap above the y key).
Then carefully hold the bb upside down and the trackball will fall out. Catch it in your hand.
Remove any obvious grit. I also used something out of a manicure set. I am not sure what it is called but it looks like a small tick remover. Anyway using one side I carefully slotted it into the small gap between the rubber ring and the trackball and lots of other bits of grit fell out.
Then once it was clean, I popped it back into the bb and refitted the cover - making sure to put the legs in the correct position.
It now works fine
Hope this helps
Phil
Jan 16, 2009 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
529 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
