Question about Dell Dimension 3100 PC Desktop
Dell 3100 suspected overheat
Its a dell 3100 2.3 gig proc its just been upgraded to 1 gig of ram from 512 it refuses to boot into windows and even has problems gettin into the bois the screen freezes with random characters letters etc on the screen ive tried every solution i can think of resetting bois the works and cant for the life o me work it out i suspect overheating any ideas anyone ???
    Scholar:
  • 74 Answers
It sounds to me like you have installed the wrong type of RAM, or it is not seated properly. Remove the RAM, and try to install it again making sure that it "clicks" into the slots. Also, look at the old RAM, and compare the numbers, if the RAM is the same speed, timing etc. as the new one, than you should be OK. Just make sure it is installed correctly. Match PC 2700 with PC 2700 etc.
Posted on Aug 05, 2009
    Problem Solver:
  • 11 Answers
Sounds like a memory issue. Run memtestx86+ from a floppy or a CD.
http://www.memtest.org/#downiso
Posted on Jul 23, 2009
    Sergeant:
  • 449 Answers
Try using Old RAM. If old RAM works well and new show the same behaviour, then new RAM timmings are not matching with the motherboard timmings. (ehteshamhusain@gmail.com)
Dell 3100 windows wont load after memory upgrade
Re-seat your memory modules and check to make sure you didn't knock any power or ide, sata cables loose or forgot to plug them back in when you were done working on the ram.
Also, make sure your RAM meets these requirements:
Type - 400- and 533-MHz DDR2 unbuffered SDRAM
Memory capacities per slot - 256 MB, 512 MB, or 1 GB non-ECC
Maximum total memory - 2 GB
If it still doesn't work then test each RAM module separately with memtest86+ to find out if one is bad.
Jun 18, 2012 | Dell Dimension 3100 PC Desktop
Windows 7 running slow after memory upgrade
If it's Windows 7 32bit it has limits on the amount of ram it can use.
Google it and see.
Jan 31, 2012 | Dell Precision Workstation 670 PC Desktop
Can't intall windows vista in my xps 700 dell pc
Even if I think it is not teh case..i suggest to check the ram memory ..and see how much you have installed on your system ..remember that for windows Vista the minimum required is !G of ram ..and a CPU ..with speeds over 1,5 G ..(which is not teh case cause this one came with a fast cpu ) ..
But the ram may be the issue ..cause on standard configuration ..it may have only 512 M of ram on ddr2 667 , and in this case will not be capable to run VISTA or windows 7 ..You actually need to upgrade the ram memory by adding at least 1G of ram ..and be sure it will run well ..(adding just a 512 will make it work but will be slow on vista..Vista is known for demanding more resources than any operation system ..I suggest if you upgrade ram memory ..to go right for windows 7 ..This way you will eliminate some speed issues..cause windows 7 is faster ..)
Another thing that may be ..is the space ...To install windows Vista or windows 7 ..you need at least 15 G of space free in the C drive ..where you want to install it ..otherwise will refuse the operation ..and stop the install process..
If you do have the space ..and teh ram memory needed..but just the partition is made too small ..I suggest to back -up files you need and can not recover from other places..and during installing ..format all drive ..by choosing advanced hard disk options ..and delete all partitions ..and make a large C drive ..(at least 40 G ) ..and the rest as you want..
format C drive and install the OS ..
The rest of the partition just create them ..cause it is possible to format them in windows.
By the way .for to be able to do all these you need to start the installing from a boot-able disk or a usb flash made boot-able with the OS on it ..cause if you run it from XP ..it will make issues..Either say you can not upgrade from xp if you run sp 1..or you can not delete the partitions if you have it active ..and running the installing from it ..So ..best way is to make a boot-able flash ..and boot from it ..by choosing it in the boot menu on start ..
A boot-able disk will do the same ..
let me know what exactly you have wrong ..and I will guide you through the process ...
Dec 06, 2010 | Dell XPS 700 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
I currently have just 256mps of memory ram on my dell dimension 2400. i want to upgrade. my manual says the maxium is 1024 mbs. can i install 1gb of ram or should i get 512 mbs? i have windows xp os. thank...
1024 is 1 gig of ram. Some older motherboards require you to put in ram in pairs but I don't think your system is one of those but if you have manual or can download manual you should check to be sure. If you don't need a pair then yes you can remove the 256 meg stick and add a 1 gig stick or you can put in 2 512 meg sticks. Should run a lot better as windows recommends at least 512 megs of ram.
Nov 20, 2009 | Computers & Internet
I have attempted to upgrade a Gateway GT52223 from 1= Gig existing 2X 512 DIMMS to 2 Gig on two separate occasions first using Using Crucial -2-1GB 240-PIN 128Mx64 DDR2 PC2-6400 UNBUFF CL6 the system...
Your last results is running your comp OK because it is really only running on the 512 stick. When putting 2 different sizes together it will only run on the smallest, with this said here is a website http://www.4allmemory.com it will test your comp to exactly what type RAM you need . I buy for my clients all the time from this website. Very reliable,Try it..and remember about the 2 sizes
Jul 15, 2009 | Gateway GT5220 PC Desktop
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
4600 Dimension Dell currently have 512 ram want to upgrade 1 gig
That computer takes PC3200 RAM. it can be ordered here: http://www.cdw.com/shop/products/default.aspx?EDC=638463
PC3200 memory can also be found at amazon.com Be sure not to buy laptop memory.
May 15, 2008 | Dell Dimension 4600 PC Desktop
Graphics upgrade
As long as you have a open vga, vga e, or pci slot in your computer you should be able to install a new video card. the Acer website says your motherboard supports up two gigs of ram, I am not sure how much ram you are running but if it is under 1 gig I would consider upgrading that also. as far as a graphics card goes get one that has at least 512 mb of its own ram so it dosent pull from your system ram as I am sure your current on-board card is doing. Another couple of hints are: if you are running Windows Vista you they call for 1 gig ram for optimal performance, also it is very important that you un-install any graphics drivers before you install new ones, and when you install the new card read the instructions completely before you do anything.
hope this helps
Carl
Feb 07, 2008 | Acer Aspire L100 PC Desktop
Dell Dimension 3100 PC Desktop Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
