Question about Philips CDR770 CD Recorder
After playing a CD for about 10mins the unit 'freezes' nothing works and to resume one has to power down. Once powered up it will run for about 2min before freezing again! Is there anyone out there who can help? Peter
  • 1 more comment
  • 836rann Jul 23, 2009
    Thanks for the mega quick reply. No it doesn't click but just before it shuts down it does go into ferocious distortion!
    Thanks for that suggestion. I've tried a CD disc cleaner and there has been no improvement but I'll try the cotton bu method. It will have to sometime tomorrow as it's dinner time here (France) and dismantling a CD recorder at the dinner table would not go down well!
  • 836rann Jul 24, 2009
    I have a Philips CD recorder which after running for about 10mins in either play or record will 'freeze' ie: the disc stops rotating and the only function available is power down. It has been suggested that a lens cleaner be used, it's been tried to no effect, and anyway it would seem to me that the problem is electronic. Incidentally the stoppage is preceded by severe audio distortion. Thanks for reading this Peter
    President:
  • 2,923 Answers
Seems that this is a common issue for Phillips CD recorders. Seems that the laser is getting weak. I would suggest you to contact the manufacturer or reseller for repair.
Here check the links below so that you could see some reviews:
http://www.comparestoreprices.co.uk/cd-recorders/philips-cdr775.asp
http://www.audioreview.com/mfr/philips/cd-recorders-players/cdr775-dual-deck/PRD_127721_2740crx.aspx
Sorry, but contacting Phillips would be the best suggestion that I could give.
Have a great day!
Posted on Jul 24, 2009
  • Philips Master
  • 13,433 Answers
When it freezes does the unit make anykind of sounds? clicking?
Posted on Jul 23, 2009
  • Ekse Jul 23, 2009
    have you tried a CD lens cleaner on it? if your outside of warranty you could open it up and clean the lens with q-tip and alcohol.
    Here is a sample video on the lens cleaning, its on a completely different device but you would clean the lens the same way on all devices.
    Also while you have the caseing open, if the drive works without the cover closed, you could look at it while its working and when the problem comes up see what happens, if the lens is unable to move that might be the issue.
  • Ekse Jul 23, 2009
    heh, alright.
Paused a disc ,when i hit play,the play light came on but nothing happened. I cannot turn off the dvd play manually. it seems to be frozen.have chaned batteries
Hi:
Try disconnecting the unit from any power source and waiting for at least 10 mins before restoring power. This should reset the units microprocessor so you can resume playing.
May 01, 2011 | Samsung DVD-1080P7 DVD Player
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Canon printer error 5100
5100 seems to be a Carriage Home Position Error. Clean the plastic strip that runs the length of the carriage, it may be contaminated. Then load the tray with the blank papers.
Then reset the Printer: Following are the steps:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
This should work. If not, install the Driver and Software from the Installation CD provided with the Printer.
You can also download the Driver from the following link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368#DownloadDetailAct
Select the Operating System installed to download the compatible Driver.
Jul 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Green light, followed by yellow light flashes 5 times, then green again. Print screen says operator error, press printer's resume button.
Hi there
You can try not really know but it like your waste ink needs to be reset.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Wait until print head stops moving
5. Press RESUME four times (if four doesn't work try three times)
6. Press POWER once
7. Press RESUME four times (if four doesn't work try three times)
8. Press POWER once
Repeating the RESUME/POWER code twice made the difference, the fixes I found wouldn't work because they stopped at step 6.
Feb 12, 2010 | Canon I960 InkJet Photo Printer
Canon Pixma MP140 freezes, only alarm lamp is on, no code error
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Jan 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Waste ink absorber is full. How do I change it and where do I get a new unit
    Reset ip2000 / 3000
    1. Turn off printer
    8. Your printer should respond as normal..
    Dec 28, 2009 | Canon PIXMA iP2000 InkJet Printer
    While playing, Player 'freezes' so all functions fail
    hmmm - slide the lid back and put a meter across the 3 power transistors that should be on the power supply board - seen from the top. (do this with the power off..:)) You may find once these warm up - which doesn't take long, they are breaking down
    Mar 05, 2009 | Numark CDN95 2-Disc CD Player
    Printer will not respond
    Canon S330 Turn off printer
    Press the Power button and the printer should turn off, if not, press the Power button once more.
    Jul 22, 2008 | Canon S 330 InkJet Printer
    Canon s9000
    This solution sounded to strange to be real but I was desperate for a solution to the orange light blinking 7 times and getting NO response from the printer whatsoever. It actually worked!
    1. Turn off printer
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    Aug 17, 2007 | Canon i950 InkJet Photo Printer
    Freezes up and will not cut off or play
    The power supply is going bad on you. I would suggest buying a new head unit as Xtreme Sound has little quality to offer in the first place ;)
    Nov 29, 2005 | Xtreme Sound WMS303 CD Player
    Philips CDR770 CD Recorder Logo
    78 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
