Question about NetGear WG111T 802.11g/b (E82321) Wireless Adapter
I am having a problem getting an ip address for my computer it's telling me that the adapter is disconnected...and my adapter blinks back and forth and can not maintain a connection
  • shaundy1714 Jul 24, 2009
    Okay, I uninstalled netgear program and reinstalled it and I was able to log on and speak to the modem. That worked!.However, It says I'm connected and it's saying my signal strength is at 100% however still not connected to the internet...Am I missing something?
    Problem Solver:
  • 14 Answers
1)Open your Pc and then Remove your LAN card
After this add your Lan Card but fix good there and see if work
2)If not, I think your problem is caused by some malwares that have damage your system files of network, so you need to reinstall or ripair your OS
Posted on Jul 24, 2009
    Sergeant:
  • 449 Answers
Try Uninstalling the driver then reboot the system and install the driver again then reboot and use the connection. (ehteshamhusain@gmail.com)
Posted on Jul 23, 2009
    Problem Solver:
  • 11 Answers
Check the wireless access points in the area. There may be another with a stronger signal that you are connecting to. Then make sure that you are not set to automatically connect.
How to find a IP address for my emachines laptop
go to start -- run and type in CMD
hit enter to open a black command prompt window
type in "ipconfig" without the quotes and hit enter. This will give you your IP address.
If you need the IP address from your provider that you are using out on the public internet, just go to http://whatismyipaddress.com/ and it will tell you what your external public IP address is.
Mar 06, 2013 | E-Machines eMachines Desktop PC
Can you tell me the default IP address for this unit as I have lost the pass word and need to reset the unit
If your computer is plugged into the router, you can easily get the router's IP address by going to your command prompt and typing "ipconfig" without the quotes.
Command Prompt is under Start (or Orb if using Win7 or Vista) > All Programs > Accessories
After typing "Ipconfig" and hitting return, command prompt should display something like this:
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : blah.blah.comcast.net.
IP Address. . . . . . . . . . . . : 192.168.0.196
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter PdaNet Broadband Connection:
The router's address is your "Default Gateway." You should be able to put that address into an Internet Explorer window and it will bring up the configuration interface.
If you find this helpful, please rate me -- trying to get my "Wiz" rating so that I can provide Premium service.
Thanks,
Chris
Jul 27, 2011 | 2wire 2700HG-B Router (2700HGB)
Recent got the wireless usb adapter for my Dell Desktop. I have run the software and the device is detecting the internet but it keeps telling me there is a problem because it is unable to renew the ip...
First, make sure that that wireless card is configured to obtain an IP address automatically, unless you are at work and they give you a static IP address. You can check the configuration by going to the properties page of the wireless adapter. You get to this page through Control Panel > Network and Internet(or something similar depending on version of windows) Right click on the wireless connection and go to properties. Right click on TCP IPV 4 and the settings should be set to auto obtain ip address.
If you are using a static IP address, then you have to manually type in the ip address in the window above.
Try the following to renew the IP address.
Turn off the cable modem, the router and your computer. After 10 seconds, plug in the cable modem, after 20 seconds, plug in the router, after 20 seconds, turn on your computer and see if this helps.
Another option to renew the ip address is the following,
Go to Start > Run and type "command" or "cmd"
Then type "ipconfig /release" once this is done type "ipconfig /renew"
If this helps thumbs up my solution!
Regards,
G33k
May 04, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
D-LINK router setup issue: We originally started with a DSL modem that was setup by the provider. We later added a wireless router and have been using it with one computer. Now we are trying to use...
A way to get around this issue is to do a static ip address for the other devices in your home. You'd have to connect to the router and set it up, i believe its by MAC address and you assign the IP.
-mk3ride
Dec 27, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My laptop doesn't have any connection this am. Can you tell me how many light should be on the router or blinking. I have a Dir-601
The router's POWER lamp should be on, and steady.
The WAN lamp should be on, but blinking when the router is sending/receiving from the Internet.
The LAN lamp should be on, but blinking when the computer is sending/receiving from the router.
Disconnect the cable from the LAN port.
Turn the router off.
Turn the router on, and watch the lamps -- they all should light up, briefly, and then the WAN lamp should blink for a short time, as the router obtains a new IP-address from your ISP.
Connect the cable to the LAN port, and watch the LAN lamp blink for a short time, as the computer obtains a new IP-address from the router.
Oct 24, 2010 | Computers & Internet
My wireless adapter TEW-444UB disconnects from network if computer stays "on" for a day or so. It's connecting again if I unplugged and plugged it again. This drives me crazy. Is it a way it designed and...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this.
Jul 13, 2009 | Trendware TRENDnet TEW-444UB 108Mbps...
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Netgear DG834Gv3 ceased to get internet connection.
Hello!
Hopefully if you try the following steps, you might be able to get to the problem.
Troubleshooting Steps
  1. Disconnect the router, and make a call with your telephone. If this does not work, contact your phone company.
  2. Reconnect the router, checking that all cables attached to the router and computer are secure.
  3. Check that the WAN light is green or blinking green. This may take several minutes after connecting or rebooting the router. If the WAN light is off or blinking yellow, contact your ISP.
  4. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual.
  5. Check if the LED on the Ethernet adapter in your computer is lit. If it is not, then troubleshoot the adapter, do not continue this document.
  6. Power off the router.
  7. Power the router on again.
  8. If you still cannot log on to the router, then do a hard reset on the router, as described below in reset router.
  9. If you still cannot log on to the router, try to get assistance from Netgear at www.netgear.com.
  10. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 14.)
  11. If a dynamic IP address is discovered, go to Step 15.
  12. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 15.
  13. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 15.
  14. If the smart configuration utility does not find an IP address:
    1. Power off the router.
    2. Power on the router.
    3. Go back to Step 10.
  15. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access!
  16. If the page does not display in a minute, you may need to do something called MAC spoofing, which I listed below.
  17. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the router and computer, in that order. Wait for the router to completely reboot before starting your computer.
  18. If the router's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are greyed out, then settings for a non-dial-up connection are being used.
Reset for routers with reset button on back panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
MAC Spoofing
  1. Connect the computer that your ISP's installers used to establish Internet connection to the router.If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records.
  2. Disconnect other computers from the router.
  3. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.)
  4. In an Internet browser type the address 192.168.0.1.
  5. Type admin for the username, password (or 1234) for the password, and click OK.
  6. Go to the Basic Settings > Router Mac Address.
  7. Select Use Computer MAC Address.
  8. Click Apply. This automatically gives the router the computer's MAC address.
  9. Click Test to make sure you are connected. If you are not connected, contact your ISP.
I tried to get everything together to try to help you out.  Hopefully this stuff will get you online!
Ken
Jan 06, 2009 | NetGear DG834G Router
Internet not connecting.
disconnect the adapter then restart computer -- re insert the adapter
you need to perform a few commands using the DOS command prompt ---- click Start > Run > type cmd then hit Enter
ipconfig /all --- hit <Enter> if you have an ip address starting with 169, then the next command you type is:
ipconfig /release --- should come back all 0's then next cmd
ipconfig /renew
Jul 08, 2008 | D-Link WUA-2340 (ASKU55774) Wireless...
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Open Questions:
See all NetGear WG111T 802.11g/b (E82321) Wireless Adapter Questions
NetGear WG111T 802.11g/b (E82321) Wireless Adapter Logo
168 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
