Cant connect to internet with LAN/Wireless, it says "make sure internet protocol bindings are correct,ensure that "internet protocol version (TCP/IPv4) and nternet Protocol Version 6 (TCP/IPv6) are selected in the configuration for the network adapter "wireless network connection".And i did that
  • jasontrane Jul 24, 2009
    im not good at computers at all.How do u reset wireless adapter / router.
    Sniper:
  • 92 Answers
Just Rwset your wireless Adapter / Router.
Posted on Jul 23, 2009
  • Amjad Saleem
    Amjad Saleem Sep 17, 2009
    RESET YOUR ROUTER
    Problem Solver:
  • 11 Answers
Disable IPV6 in the network adapter configuration.
Desktop will not conntect to internet, but it says connected. My laptop works with the wireless network connection just fine, however, we cannot get the desktop to work. any suggestions? i have been on...
You didn't mention if your desktop is connected hardwired or wireless. Let's assume your desktop is connected hardwired via ethernet cable and your PC is saying that your are connected, then you need to check 2 things. First, TCP/IP settings, go to the network connections page of your PC and look for Local Area Connection. You need to right click on Local Area Connection and click on Properties. Then on the next page, look for Internet Protocol (TCP/IP) or Internet Protocol version 4 (IPv4) for Win Vista and Win 7 OS. You need to click on it to highlight it then click on Properties. On the next page, make sure that "Obtain an IP address automatically" and Obtain DNS Server address automatically" are both selected. Sorry if cannot give you a detailed walkthrough because you didn't mention the Operating System of your PC. Second, check Proxy Settings, open up Internet Explorer and click on Tools on the upper portion then click on Internet Options. On Internet Options page, click on the Connections Tab then click on the button for LAN settings. On the next page, make sure that the "Use Proxy Server for your LAN" is unchecked.
Sep 14, 2011 | Computers & Internet
Have a Belkin N150 router. Status constantly says acquiring network address. If you go to the support part it says invalid ip address.
Make sure your wireless card is set to acquire the IP address automatically. You can do this by going into:
  1. Go to "Start Menu >> Control Panel >> Network Connections"
  2. Right-Click on "Wireless Network Connection"
  3. Click on "Properties"
  4. Double-Click "Internet Protocol" which you should be able to see in the small list in the box
  5. Now you will be able to see an option to "Obtain IP address automatically" and "Obtain DNS server address automatically". make sure that both of these options are selected.
If you have Windows Vista or Windows 7, the flow is the same, but certain options are labeled differently:
  1. Go to "Start Menu >> Control Panel >> Network and Sharing Center"
  2. Click on "Manage Network Connections", which is located on the left hand side of the window.
  3. Right-Click on "Wireless Network Connection"
  4. Click on "Properties"
  5. Double-Click "Internet Protocol Version 4" which you should be able to see in the small list in the box
  6. Now you will be able to see an option to "Obtain IP address automatically" and "Obtain DNS server address automatically". make sure that both of these options are selected.
  7. Repeat 'STEP 4 and 5', but this time select "Internet Protocol Version 6".
you can check the IP address of the connection by checking ipconfig:
  1. Click on "Start >> Run" or "Start >> Start Search bar"
  2. type in "cmd" and then press "Enter"
  3. In the black box that appears on screen, type in "ipconfig" and hit "Enter"
  4. This will give you a long list of information about your connection. There should be a small heading called "Wireless LAN Adapter Wireless Network Connection" or "Ethernet Adapter Wireless Network Connection".
  5. This will have an "IP Address" or and "IPv4 Address". If the IP Address starts with 192.168., then it means it should be functioning properly. If it gives you a 169.254. address, it means the laptop is likely faulty.
Hope this helps
Mar 05, 2011 | Computers & Internet
Can't connect to wireless router
1.Ensure ethernet cord coming from modem is plugged directly into internet port of router.
2.Powercycle equipment (Unplug power from home modem and router wait 15 seconds then plug back in
3.Open Network Connections XP:Start/Run/Type ncpa.cpl
Vista/7 Start/Search bar/Type ncpa.cpl
4. A.Right click on wireless connection the connection you use with router and hit properties,
B.Uncheck Internet Protocol Version 6/ Click on Internet Protocol Version 4 and hit properties,
C.Ensure Obtain an ipaddress automatically is checked
Ensure Obain a DNS server automatically is checked as well
5.Open Command Prompt XP:Start/Run/Type cmd
Vista/7 Start/All Programs/Accessories/Right click on Command Prompt hit run as administrator.
6.Type in Command Prompt: netsh int ip reset reset.log (Hit Enter after each command)
netsh int ip delete arpcache
netsh winsock reset
ipconfig /flushdns
7.Restart Computer
8.If still unable to access internet Disable Firewalls/Antivirus
Dec 14, 2010 | Linksys Wireless-G WRT54G Router
I hsve problem with wireless driver in toshiba satellite l455-S5000 in windows 7-32bit its done install wireless driver and windows see wireless lan realtek RTL8187B wireless 802.11b/g 54 Mbps but...
Intel Wireless LAN Driver for Windows 7 (32) Posted Date: 2016-09-21 ' Version: 12.4.1.11.0 ' Size: 4.43M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 1.0.0.196.0 ' Size: 21.82M Atheros Wireless LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 8.0.0.144.1 ' Size: 21.79M Realtek LAN Driver for Windows 7 (32/64) Posted Date: 2016-09-21 ' Version: 7.003.0522.2009 ' Size: 7.26M pls remove the back cover and check wireless card label and download the correct driver.
Oct 01, 2017 | Toshiba Satellite 1415-S105 Notebook
I baught this belkin router at a yard sale,when I got it there was no disc to install it on my computer,I have hooked it up and it says I am connected but when I try to get on line it can't find the sever.
From what I can tell you are using Mozilla Firefox Try using Internet Explorer if ip address id not valid it will tell you Internet Explorer cannot display webpage In order to renew ip address these are the steps you will want to take:
1. Ensure the equipment is connected correctly(Ethernet cord from modem to Internet port on router
2.Open network connections Win XP:Start/Run/Type ncpa.cpl
Vista/Win 7 Start/search bar/type ncpa.cpl
3.This will bring you to your network connections window
4.If using XP: Double click on wireless connection and hit the support tab. Ensure it is assigned by DHCP and the ip address should start with 192.
5. If Vista Or Windows 7 Right click on wireless conenction and hit properties. Uncheck version Internet Protocol Version 6
6. Click and Highlight internet protocol Version 4 and hit properties
7. ensure that it shows obtain ip address and obtain a dns server automatically
8.After go to Command Prompt (Win XP) Start/Run/Type CMD
Windows7/Vista:Start Start/All Programs/Accessories/Right click on command prompt and hit run as administrator then hit continue type in these commands.
1.netsh int ip reset reset.log
2.netsh int ip delete arpcache
3.netsh winsock reset
4.ipconfig /flushdns
9. Restart Computer hope this helps please rate thank you
Sep 30, 2010 | Belkin (F5D5231-4) Router
I cant log on to the internet on my other computer it tells me minimal or no connection
Please ensure that your security settings are correct. Also make sure you have entered the correct password in your security enabled network (sounds like you are using a wireless connection). If you are behind a firewall or proxy server ensure that the internet settings are correct. If your are using IE go to tools - internet options- connections- LAN settings to setup your proxy if you are using Firefox go to tools - options - advanced - networks - settings tab to configure your proxy. The steps are almost identical for all browsers.
Sep 30, 2009 | Microsoft Computers & Internet
Xbox live via cricket wireless
I can connect to XBox Live through this fashion on my Cricket Modem:
Now, I have had problems with this fix running Windows 7 (still can't get it to work), but I didn't have any struggles with XP or Vista.
You need to go into Manage Network Connections, right click on your Cricket Modem, and select Properties.
Click the Share Tab, and click it so it allows other users to connect through that network connection. Now, go to the Networking tab under Properties and right click on the Internet Protocol Version 6 and make sure it is automatically assigning both DNS and the 6 IP, Apply.
Next do the same with the TCP/IPV4 section under Networking, make sure everthing is automaticaly assigning.
Click on the Router and make sure that it is automatically assigning the Internet Protocol 4 and 6. Now click diagnos, and it should reset the router, automatically apply the correct settings, and bam. You SHOULD be able to connect with XBox Live.
I have no problems with this with Vista and XP, as I stated before. But now my main computer is running the 7 RC and I can't figure the darn thing out yet. So I figured out a cute solution. I took my Dell Mini, connected the Cricket Modem to it, and ran an ethernet cord from the XBox to the Mini.
Pretty much same solution after that, only instead of selecting your router, you select the LAN connection that is not your Cricket. For me itassigns the XBox as LAN and the Cricket as LAN2.
Let's see how it goes. :)
Jul 19, 2009 | Computers & Internet
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Wireless can not communicate with my comp
I'm assuming you are using windows XP or similar. You can check your tcp/ip protocols and local pc adaptor by 'pinging'. open the command prompt - 'start', 'all programs', 'accessories', 'command prompt'. Then type 'ping 127.0.0.1' without quotes. If there is 'no loss' of data, your pc is basically sound, as are the protocols.
Try reaching your router by typing 192.168.2.1 (or look on bottom of router or documentation for IP address). It may ask for user name and password which should be with documentation. You need to be able to reach your router before you can use the net.
If using a cable, check out your LAN by going to 'control panel', 'network connections', then find the LAN icon. Right click and left click on 'properties'. under the 'general' tab scroll to ' internet protocol tcp/ip'. double click on this. under the general tab make sure ip address and dns is obtained automatically.
If you're using the wireless capability (ie not network cable) right click on the wireless connection to 'view available networks'. try to connect to one. You may need a WEP/WPA etc password. You could try connecting a network cable from pc to router to see if it's a wireless problem or not.
In control panel look at 'internet options' and 'connections' tab. make sure it's set to use the right connection (eg mine just uses the LAN).
sorry if this is a bit muddled but there are many possibilities. Any more info on your setup would be helpful.
Dec 04, 2008 | Belkin (F5D7230-4) Router (587009)
WINDOWS VISTA - CAN'T SET UP LAN: SOFTWARE NOT COMPATIBLE?
I don't see Vista listed in the SBG Manual, but they do list several windowS OS versions. Looking at Windows 2000 for an example, you basically need to go into the control panel and make sure TCP/IP is configured correctly.
If Internet Protocol (TCP/IP) is in the list of components, TCP/IP is installed. You can skip to step 10.
If Internet Protocol (TCP/IP) is not in the list, click Install. The Select Network Component Type window is
displayed:
In both cases, the box next to Internet Protocol (TCP/IP) needs to be selected.
If you need the steps in selecting the network component type let me know and I'll try to post those steps also.
Mar 03, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
