Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Unable to receive US channels on my HDTV Projection Monitor
I have a tower antennae and recently the US channels switched over to digital transmission and I lost all the US the channels.I still receive Canadian Channels
I would like to to know if I need a DTV converter box to enable the US channels. I was under the impression that my present antennae should work without a converter box since it is an HDTV. I would appreciate some help as to what I must do.
My HDTV Panasonic Projection Monitor model number is PT-47WX53.
Thanks Andy
    Sergeant:
  • 273 Answers
No you need a digital decoder
Posted on Jul 23, 2009
What antenna works on Toshiba 20VL43U? I purchased Mediasonic Homeworx HW110AN Super Thin Indoor HDTV Antenna - 25 Miles Range.
I recently went through a whole song & dance about HDTV antennas for my RV. I bought two different directional high-gain antennas, only to find that they wouldn't even receive signals at my home! When I'd reorient the antenna and initiate another channel search, I would sometimes get ONE or TWO channels... then I'd lose them when I'd try to reorient the antenna.
What I figured out is that DIRECTIONAL HDTV ANTENNAS ARE, ESSENTIALLY, WORTHLESS. There is really no way of knowing precisely which direction the broadcast towers are and, even if you knew, they will not all usually be clustered in one small area... they may be scattered here & there around your area.
What I eventually did is bought an OMNIDIRECTIONAL HIGH GAIN ANTENNA, which was no more expensive than the DIRECTIONAL antennas I tried. Did a channel search, and got almost all of the channels in my area!
Any omnidirectional HDTV antenna will work with your television, but I'd recommend buying the one with the highest GAIN (expressed in "dB" or "dBi" with the highest number being best). Try to find a POWERED antenna with an internal SIGNAL AMPLIFIER.
Also, if you live far away from broadcast towers as I do, you may wish to consider adding an additional SIGNAL AMPLIFIER as well.
May 21, 2015 | Toshiba Televison & Video
Digital channels antenna
If you have a HD TV then you do not need a converter box, however you will still need an antennae to receive the channels. the antennae can be hooked up directly to you're HD tv.
Oct 27, 2013 | Toshiba 46H84 46" Rear Projection...
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
I purchase a Sony Bravia KDL-32xbr6 in 11/08. I want to get rid of satellite due to bills increasing. I cannot figure out if I have an HDTV tuner inside the tv or not. Anyone know? DO I need to...
Your LCD has a digital tuner and should receive free channels using an indoor antenna but it would receive more channels if you have an outside antenna, depending on where you're.
If you are closer to a transmission tower the indoor antenna should work fine.
Let me know if you need further assistance.
Oct 02, 2010 | Sony Televison & Video
Samsung hlp 4663w does not receive off air signal from roof antenna through antenna ports 1 or 2. Get cable signal just fine through same ports. Same antenna works fine on other tvs. Whats the problem and...
If you're in the US, you will no longer get antenna signals because the US has recently switched to digital. The TV you have does not have a digital tuner and you'll need to purchase a digital converter box that converts a band of analog signal to digital.
Feb 03, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Does this tv have a digital tuner? i thought it did because it said hdtv on it when I bought it in 2004. but I just bought a digital antenna and i'm getting nothing but snow after i scan for channels. is...
Sorry to say, your HDTV-Ready - Requires separate receiver to view HDTV signals. SDTV (Standard Definition) - has built-in digital receivers/decoders and do not require the purchase of any separate components in order to display digital signals. It provides lower image quality than EDTV or HDTV, but higher image quality than analog TV. SDTV is displayed using an aspect ratio of 4:3. I hope this helps and good luck.
Please remember to vote fe52ba2.jpg if this was helpful in any way. Thanks.
Oct 31, 2009 | Hitachi 46F500 46" Rear Projection...
Need help locating a box to make my TV receive true HDTV
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
Dec 27, 2008 | Hitachi 51F510 51" Rear Projection...
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
DTV connection
Have you tried http://www.antennaweb.org/aw/Address.aspx? This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
Nov 10, 2008 | Televison & Video
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
