Question about Toys
The track has spots with less power?
There are parts of the track with less power, this is in different places on both lanes.
  • 850 Answers
Clean track joins! as continuity between them has been reduced
Posted on Jul 23, 2009
My sthill bg 86 blower has had a slight flat spot when reving it from new - it had its first service but no difference after that . six month down the track it has become so bad it wont rev out at all
When you say flat spot do you mean it goes from full throttle to slightly less with a slight puttering noise intermittently? If so this is the governor, totally normal, however from the description it sounds like a fuel and or vacuum related issue, Most likely the carburetor has failed or needs rebuilt, or the fuel lines or fuel tank vent have failed
May 20, 2011 | Garden
Have a 2004 Peterbilt 379, headlight setting is terrible, tried setting them by eye but just not right, does any body have any specs or ideas?
Yes, if you are running over- the- road just stop in a State that has vehicle inspections and they can set the lights to their specs. In those States that have an inspection setting the headlight aim is part of the job.
Next method, park your unit about 20 feet from a garage door or the side of a building or carwash. Use some tape or pencil and make 2 crosses. The passenger side is allowed to be high and slightly to the right. A correctly aimed right headlight will focus on the curb or lane marker with the right headlight spot-on the lane marker. This will mean you will be safely within your lane on the right side of your truck as long as the headlight hits the lane marker.
For the left light it is suppose to be almost straight ahead and not tipped out to oncoming traffic. In some States the left light is turned slightly towards the center of your truck. You can check against the crosses you put on the surface of the building and watch the beams move as you adjust the lights. Use some chalk to mark where the tires were so you can get into the same spot.
I had to do some Vehicle Inspections in Texas years ago. I want to say the headlights were suppose to be 42" high at 20 feet, but you have a Peterbuilt. And now some of the cars are barely 48" high.
Mar 04, 2011 | Ford F-150 Cars & Trucks
I own a 2000 Toyota Camry, 4 cyl. Driver side power window rolls down fine but when rolling up comes off track. The front part of the window is lower than the back. All other windows work o.k. I installed...
I just did one on my Chrysler. May be quite different, but I'm suspicious that the track was creased or the fur damaged in some way when you had the original problem, or the track is not secured tightly to the door frame. The regulator keeps the glass pretty even but if the window binds on a crease, or whatever, I guess it could get jammed and slide out the crease instead of up the slot. Good luck. Those accursed things are frustrating work in hard-to-get-in spots!
Dec 19, 2010 | 2002 Toyota Camry
Passenger side power sliding door stops part way
Had the same problem on ours. It stopped about 6 inches away from being closed. I could advance it and press the button, and it worked. About two weeks later it stopped working altogether. I had a black wire that was cut through. Trace the wires inside the black plastic wire mold track that looks like a tank tread. You might be able to see the cut. There are about 5-6 wires inside the track. Undo the wiring harness where the wire mold attaches to the sliding door gear. If you get a lighted 12vDC pencil tester (~$5), press the door button so it opens, and poke one of the wires in the wiring harness. If it lights, the connection is still fine. If it doesn't light work a little further back until the light comes back on, and some point in between is the cut. Using a flat head screwdriver, you can snap off the links of the wire track mold. They just snap back on with a firm grip.I resoldered the wires and some electrical tape.
I realized that when it was stopping part way the ends of the wires just happened to touch and allowed it to move, but when the door got so far the wire track had to bend separating the connection. The repair has been working for about 4-5months now.
Feb 18, 2010 | 2005 Chrysler Town & Country
1997 Jaguar xj6 - car wants to track grooves in roadway
This could simply be your tyre width, the wider your tyres the more they want to hold onto the road, if there is a groove the wheel will want to follow it, thinner tyres would solve the problem but affect the way the car handles, it is a coomon thing and generally nothing to worry about.
Dec 19, 2009 | 1997 Jaguar XJ6
How do I order more straight track for my Fast Lane race set?
ebay try them theyr normally verygood for these
Sep 21, 2009 | Toys
Lossof power and ets off inicator on
check fuel pressure 1 fuel pump 2 fuel pressure regulator and 3 fuel filter.
Oct 30, 2008 | 1998 Chevrolet Cavalier
Toys Logo
35 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
