Question about RCA HD52W58 52" TV
Error on screen showing 'unusable signal' - input probs
Question: i have screen picture, not necessarily sound yet because for some reason i am unable to get the inputs to show a picture. screen lets me navigate through options and i have all inputs 'unlocked' however when connecting a dvd player (with red, white and yellow) -- it is still not recognizing anything as the screen shows an error stating 'unusable signal' inside a red rectangle with a red circle around the wording...
please help, the picture is great but it wont connect to anything for viewing. Thanks.
  • 616 Answers
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
I have a 42 inch panasonic plasma tv, I have great picture and sound on hdmi input only
From a quick look at the tv spec it would seem to cope with most inputs so I wonder if it may be due to input type selection. Mine on some inputs have sub options on its inputs which would be in the screen menu (mine has rca sockets and can become component or normal video input).
You say you can hear sound but no picture which sugests there is a signal of some sort (tv's and video's inputs become live when a video signal is present but if its poor in some way will not show) but allow sound through.
If the game is old then it may not conform to modern standards so present a blank screen. its hard to say what may be the problem but I think input selection or an incompatible signal looks to be a possible answer (if you have your plug ins correct)
Hope this helps.....
Jul 02, 2017 | Panasonic Viera TH-42PZ80U Plasma TV
Rca unusable signal
Your TV could be on the wrong input source. if your using red/white/yellow cables look for an inpout button or source or even TV/Video. your tV has many inputs on it and you can only acess them 1 at a time, this allows you to toggle through the input sources and when you get to the right on you'll have picture and sound
Sep 29, 2013 | RCA Televison & Video
Input0, cablecard, sound but no picture
Could be a tuner issue but if not tried unplug set and a box if used from power for a while and then power them back---also do same if using a receiver in the line as well.
Failing that you can get around this (if a bad tuner) by routing signal to a unused rear input, bypass the problem.
Dec 14, 2012 | Toshiba 72HM195 72" HDTV
My 61in rca scenium is saying unuseable signal and there is no sound or picture
For whichever input the monitor is currently set to (i.e. Input 1, HDMI 2, etc.) it is telling you that the signal it is receiving is unusable. The question first is the monitor set to the input you truly wish to use?
If it is, then check the cabling between the monitor and the source device (cable/satellite box, game box, etc.) If you believe it the source is working, try swapping the cable or using a different input.
If that fails, try hooking up the source to another monitor and seeing if it works there. If you have a long cable run, try higher quality cables, the video signal can degrade over long runs (> 25').
It sounds like the monitor is receive *a* signal, just not one with enough data to be useable. Probably a bad cable.
May 06, 2011 | RCA Televison & Video
My screen is green and does not show a picture or sound! You cannot change the channel or access the menu! Is it the picture tube or lamp?
Can you see menus if you press the menu button? You could be set to the wrong input that doesn't have a signal coming in. I have one TV that shows a blank blue screen when I'm on an input that has no signal. If there is not a signal on the input being used you will also not have sound.
Mar 21, 2011 | JVC Televison & Video
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
No picture only sound when playing dvd, screen says unusable sighnal
Change the signal cable, the video cable. Either its loose or its broken. Try using diff input on ur TV
Jan 16, 2010 | Philips Televison & Video
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
RCA HD52W58 52" TV Logo
141 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
