Question about Maytag SAV3710AWW Washer
I have a 1978 Maytag washer, how do I adjust the tension on the belts?
  • Anonymous Mar 30, 2014
    what is the proper tension for the listed washer?
    President:
  • Maytag Master
  • 1,922 Answers
That machine like most brands of washers have an "idler"pulley to automatically adjust belt tension,either "idler" is defective or belt is off a pulley somewhere under there,tip washer against a wall with a towel so you dont scratch washer finish and have someone steady it while you check those things out.
Posted on Jul 24, 2009
Maytag top loader will not drain all the water out of cloth during the spin cycle
belt tensioner idler pulley out of adjustment or damaged. or belt is worn out. belt is at bottom of machine and if you remove lower front cover, you can run the machine through a cycle and see the problem. my pulley fell off the shaft was on the ground and I had to replace the assembly.
Apr 21, 2014 | Maytag MAV8757AW Top Load Washer
Why won't my Maytag Washer extract water properly from clothing after going through the complete cycle?
Belt tension spring faulty, belt loose. Pump partly blocked, look for coin caught in hoses. Internal clutch failed in gearbox, replace gearbox. Gearbox pulley wrongly adjusted, remove pulley, re-grease, re-install with correct clearance.
Dec 18, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag performa pavt244aww washer burnt rubebr and black pieces
Check with the belt off that the bowl will turn freely, if not check drum bearings or something caught between inner & outer bowl. Make sure when you fit new belt it is adjusted to the right tension or it will slip & burn.
Nov 24, 2013 | Maytag Performa PAV2200
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
Belt tension too loose
the typical tensioner should be able to be bent a little to tighten up the tension
Sep 27, 2012 | Maytag Parts Maytag 801429 Dryer MAYTAG 30...
How do I change a broken belt on washer
With most machines the back case comes off and its simple to do /Belt slips over the pulley then onto the motor Shaft, with some machines you may have to loosen the motor to adjust belt tension, making sure belt will not slips or be too tight which could result in bearing stress..Good luck
Feb 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
How do I adjust the pump belt on Maytag washer ?
Depends on model.
For top load units with two belts under botton panel, tilt empty washer against a wall to allow access to belts and loosen the 3 pump mounting screws. See page: http://www.applianceaid.com/maywash_belt.html
Jan 07, 2010 | Maytag Atlantis MAV5000
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
How to replace Maytag Washer belt
I have a model sav2655aww maytag washer. And it needs a new belt but I dont know how to replace it! Can the pump be removed with out removeing the motor ? Also the tub keeps going off center whats with that ?
Sep 03, 2007 | Maytag SAV5710 Top Load Washer
Maytag SAV3710AWW Washer Logo
234 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
