Question about Samsung 2343BWX 23 in. LCD TV
Bought new Samsung Syncmaster 2343. Can't
Bought new Samsung Syncmaster 2343. Can't get stand to tilt...don't want to force metal plate
to tilt back...does it need grease...I don't want to break it...does it need inordinate force to tilt the metal plate back in it's plastic stand? Any suggestions?
Barry
  • 616 Answers
Read the instruction manual. Julio milleniumtvsvc@gmail.com
Posted on Jul 23, 2009
How do I adjust the tilt function. It seems it is stuck
Tilting on most Monitors is designed to require some force to prevent it from slipping.
Gently yet firmly hold down the base of the monitor on the desk with one hand. Then place a second hand on the bottom of the screen and pull it towards you using even pressure. It will slowly move.
Please also keep in mind that your monitor may not be able to tilt much. If you need it to tilt further, you can buy an alternative stand for it.
Apr 07, 2011 | Samsung SyncMaster 740BX Monitor
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
My monitor still works great and I love it. However, in trying to move the tilt adjustment, the pop-metal tabs that slip into the back of the monitor screen snapped right off. Is there a way to purchase...
I'm pretty sure that these monitors are built/assembled overseas and it would not be worth trying to get buy a new base (if it was available). Your best bet is to have someone build you a new frame to support the monitor in.
Regards,
Yavacotech
Jan 16, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
How do I tilt the monitor?
Look on the back/side of the stand for a little locking button.
Jun 20, 2010 | Samsung SyncMaster 2032BW 20" Monitor
Samsung 940MW monitor will not cut on. Green LED flashes only
Most likely it is a set of bad caps on the power board. If you are okay at soldering to do the following with the unit unplugged:
Remove the back cover:
  • Remove the 4 screws that supports the stand and slide it out the bottom.
  • Remove the 3 screws along the bottom of the back plate
  • Use a small flat blade screwdriver or plastic wedge (less risk of damage with wedge) to press on the release tabs around the sides.
  • When removing the cover make note of the antennae connection since you will have to work around this
Remove metal cover over circuit boards:
  • Remove 8 (if I remember correctly)screws securing the metal case. Do not remove the screws securing the LCD panel to the frame
Inspect the power board:
  • Look towards the top of the board for capacitors that have a bulge or brown "gunk" on them. If you have some that are this way this is most likely the problem.
Here's a picture of 4 bad caps on a 940mw. Once I replaced the caps the panel works great and had the same issue as yours.
Oct 09, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Tv stand on the wall
It is not made for wall mounting unless it has 4 bolt holes in the back cover. Some wall mounts grip the tv on top and bottom, but they look like hell.
I bought the same Samsung, but took it back.
Dec 28, 2008 | Samsung SyncMaster T200 LCD Monitor
Broken Stand
ya..tats replaceble..jus ask in the shop where u buy your monitor..
Sep 05, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor tilts down
Is there a bolt to tighten down in the back?
Aug 29, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
Samsung 2343BWX 23 in. LCD TV Logo
297 people viewed this question
Jerry Greenberg
Jerry Greenberg
