My Citizen C479 dvd play is showing ''key lock on''. I have no idea how it got on and can't find a way to turn it off. I have tried unplugging it for periods of time, even over night with no effect. It plays the dvd but won't let me eject it. I have tried emailing the companies technical support but so far I haven't received and answer. Does anyone have any idea how to turn this key lock off and get the dvd out?
NO PC told PAV means nothing, PAV is both laptop and desktops for decades 10,000 models,+
the button on the try must work, it's electrical.
NO OS told is it windows, is it w8? or w7 or vista or XP>
The OS windows , you open local explorer. (this PC)
and right click the DVD drive and pick EJECT. that too must work
both must,
some APPS lock the DVD, , say a DVD player of any kinds
power off the PC
and turn it on and hammer esc key and at the prompt click F1 or F2
and go to BIOS page 1.
now the front DVD tray eject works, (button physical)
if not the DVD drive is JAMMED.
It sounds like your DVD is not getting any power to it. When you press the eject button does it show a power light for a second and then not move ? Also it is possible that some other DVD could have been in it and now it is blocking the door to open, look carefully at the door there should be a very small round hole on it you can use a paper clip straightened out to make a probe and insert it in the little hole and push you will have to push firmly and it should open the drawer. I hope this helps
Hey.. I was having exact same problem, and couldnt find answer anywhere online, so i actually called citizen.
SO>>> hopeuflly u have ur remote.
Push setup.. then push 00083 then enter.. and there ya go.. problem fixed. YAY>.
If u dont have remote.. not too sure. but heres there number.
18006635954
You cant you have to use a remote you can get universal ones from woolworths. But make sure that its supports your dvd player look at the back of the packaging.
If you have any questions please dont hesitate to ask
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys: SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Power up the unit with no cd/dvd on the tray Press "eject" on your remote to eject the tray Press "setup" on your remote Key in "5018" using your remote Key in "0" Press "play" on your remote
Tada~ a region free dvd recorder
Tried this but unfortunately the machine keeps reverting back to Region 4.
Has a step been left out or is there some other way of changing the code to "0".
The disk cannot be taken out by setting the Tray Lock, please follow the steps below.
Turn Unit ON.
Set the DVD to the Stop Mode.
Press and hold the ‘STOP’ key on the front panel.
Simultaneously press and hold the ‘9’ key on the remote control unit.
Hold both keys for more than 2 seconds.
Press the OPEN/CLOSE key on the front panel to check the Tray Lock setting.
To unlock the Tray Lock, please follow the steps below.
Turn Unit ON.
The Tray Lock has now been cleared.
while the demo is playing you must press "Play"and "Stop" buttons, then display shows DEMO OFF and you can now take the DEMO CD out. In some models you need to turn off the power and turn it on while pressing the EJECT Butoom. SONY SPECIALIST
