Pressure reading for goodman a/c unit ssx16 5 ton unit
Need tro know what should be the high and low side preesure reading w/ the new 410 freon
  • 158 Answers
Lp-860kpa hp-@2400kpa . For inverter a/c it will vary according to ambient temperature and max to those pressures
Posted on Jul 23, 2009
Can I buy a new inside unit for a MS24WN outside unit
EPA regulations: Freon 22 units are no longer available, Units that are compatible are available They come pre charged with nitrogen It must be dumped. If there is freon in the old system it should be pumped down into the condenser unit before the inside unit is removed, Close the high side king valve and run the unit until the low pressure reads near O Close the low pressure king valve. and turn unit off. 410A freon units are readily available. Most if not all 2 ton air handlers will work with any outside 2 ton unit though some building codes will not allow a mix. Their reason: if something fails who is to blame:
Dec 02, 2014 | Heating & Cooling
What are GSC130481AC low and high pressure readings
65to 78 psig on low side 210 to 270 on high side. higher values when house is warm.
May 01, 2014 | Goodman Heating & Cooling
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
Goodman ac 3 ton freon readings
typically 68 to 75 psig depending on ambient temperture and load on unit.
Apr 03, 2013 | Goodman Heating & Cooling
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
Temp off air coming out of register 74 degrees suction line temp is 42 degrees but high side line isnt warm dont look like it is wanting to take freon either compressor is running new system low side is...
Hello, what is your high side pressure? A bad compressor will show abnormally high low side pressure with abnormally low high side pressure. That 45 low side pressure is low And superheat high. If you high side pressure is normal toma little above normal but the low side remains low you have a restriction in the system, that might be why it's not taking in tne freon. Let me know you high side pressure
May 11, 2011 | Goodman Heating & Cooling
What should the pressure readings be for a American Standard Freedom 500 2.5 ton air conditioner be
Hi, this depends on the outdoor air temperature and type of freon this unit has. The hotter it is outdoors, the higher the pressure will be as they use a pressure/temperature relationship. If the unit is R-22 and lets say it is 90* F. out side, the low side or suction side will be at around 68 to 72 p.s.i which would give you an evaporator temperature of 40* F. Head pressure would be at around 90* plus 27*= 245p.s.i. This is if the condenser fan is in good condition and the outdoor coil is clean. If you are using a set of manifold gauges you have the pressure/temperature scale right on it. If the unit has a TXV for metering, you would need to charge it using the subcooling method. On a Non-TXV you would use the superheat method. If you are using the new R-410a freon, the pressure are extremely high in these systems compared to the R-22 system, so make sure you look at the units data plate to read the type of freon. The color of the container is green for R-22 and a Pink for R-410a and the 410 a unit will display a pink warning sticker on the unit to tell you. The pressures on the R-410 would be at 90* F, low or suction side at that temp is around 125 p.s.i., and around 400 to 420 p.s.i. on the high side, much higher then the R-22. You would also need a manifold gauge set made just for the R-410a (AZ-20) as of the extreme pressures in the system. There is never a set pressure to go by as the outdoor temperature will raise and lower the pressure of freon very fast. If you are asking this question because you have a manifold set and are taking a reading, the unit has a charging method pasted right on it from the factory showing what pressure they want it to run at. Your gauges also can be used as a pressure temperature chart, or you can pick one up free of cost at a a/c parts house to keep with you. It will show you how to calculate the charge for your unit. If you are familar with pressures, this should be of a great help to you. I hope that I have helped you on getting the unit charged properly. Please keep me in mind when rating me, as I know you will be kind. Just drop by a wholesale a/c parts house, walk in and ask for a pressure temperature chart, and they will hand you a couple of them. They have very good information and no how on all of the most common freons in use today.
Best of luck
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 29, 2010 | Heating & Cooling
AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
May 27, 2010 | Goodman CLQ36AR49 Air Conditioner
Looking for freon capacity for 5 ton goodman package unit, cannot read serial or model number.. unit is 1998-2000 model ,, we just replaced the accumulator and we are not sure how much freon to put in.....
check low side which is the bigger of the two, make sure you tighten the hose good. your reading should be 65 psig.If not add refrigerant/r22 . if r410a 110 to 115.
Apr 14, 2010 | Goodman GPC1342H21A Air Conditioner
5 ton goodman ac unit
You MUST WEIGH IN THE NEW CHARGE OF R-22. There should be a label on the side of the a/c unit that states what the factory charge was. This is only a starting point. Once you have the factory charge in the system, then turn on the unit and allow it to stabilize (5 min) . Check pressure on low side and check teperature on low side pipe. Temperature of pipe should be 8 to 15 degrees above what the boiling point of the refrigerant is for the current pressure you are reading. If the temperature is more than 15 degrees, add R-22 in 4oz increments allowing 5min in between each time you add until you are in the "zone". When you do this, your head pressure needs to be 225-250. if you need to cover the coil or block the outdoor fan to do this then do it. Hook up the vacuum pump and start over
Jun 17, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
185 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
