Question about Lands Phones
I cannot connect my bluetooth headset to my phone
  • 390 Answers
Turn on the Bluetooth on the phone and now while switching on the bluetooth headset hold the power button and and the Volume+ button and hold till you see a constant blue light on the headset
now the phone recognises the headset and asks for teh pass code enter 0000 on the phone and your headset has been paired with the phone
this is a one time process and the headset can be paired with one phone at one time and this process can be repeated any number of times with any number of devices
Posted on Jul 23, 2009
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Tip
Jabra Bluetooth Headset Pairing Instructions
<span><span>Connecting a Bluetooth headset or car kit</span> <span> You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free. <ul> <li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li> <li>Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual. </li></ul> <ol> <li> <span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> &gt; <span>Wireless & networks</span></span>. </span> </li> <li> <span>Tap <span>Bluetooth settings</span>. </span> </li> <li> <span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span> </li> <li> <span>Make sure that the headset is discoverable. </span> </li> <li> <span>Tap <span>Scan for devices</span>. </span> Your phone will start to scan for Bluetooth devices within range. </li> <li> <span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span> Your phone then automatically tries to pair with the headset. </li> <li> <span>If automatic pairing fails, enter the passcode supplied with your headset. </span> </li></ol> The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls. </span></span>
on May 23, 2011 | Cell Phones
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
Feb 21, 2011 | Itech Blue Pro Bluetooth Stereo Headphones...
I cant pair my bluetooth with my phone
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Jan 28, 2009 | Jabra BT350 Bluetooth Headset Headset
SAMSUNG BLUETOOTH PAIRING
4.Select (Serched bluetooth device) once a connection is detected.
Tips:
Dec 04, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth problem
4.Select (serched bluetooth serched device) once a connection is detected.
Tips:
Jul 28, 2008 | Motorola Mobility Bluetooth Hands Free...
How do I set my Bluetooth Headset HBM-730 to discover mode?
4.Select HBM-730 once a connection is detected.
Tips:
Apr 20, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Plantronics bluetooth
you have to first put bluetooth headset in pairing mode by holding the phone hook button down until blue indicator on headset goes solid blue not flashing then set your phone to find bluetooth device by looking under your phones menu and look under bluetooth or connections make sure to turn on bluetooth function and choose find or add device phone will detect bluetooth device and will display the type of device on your phones display tell it to bond or connect once you select yes thats it the bluetooth headset will start to flash and its ready to go.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Lands Phones Logo
178 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
