Question about Kenmore 24032\24036 Top Load Washer
Fills with water but doesn't stop
Does not stop filling with water once started had to shut off water manually.
cycle knob just free spins now but it was working before the overflow is the cause or possible a byproduct? can't the circuitry is there some tip to getting in there?
    Top Expert:
  • Kenmore Master
  • 80,263 Answers
The washer timer control has failed, u will need to replace it.
Posted on Jul 23, 2009
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 70 Series Washer Won't advance in the
    Bad timer. Try to find a used one if possible, this item is a little expensive.
    Aug 23, 2010 | Kenmore Washing Machines
    My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
    Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
    Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
    Washer stops after aggatating and wont drain
    My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
    Jun 10, 2009 | Whirlpool Washing Machines
    Washer fills with water, spins but does not aggetate
    LG washing machine, the water continue, not stop
    Mar 15, 2009 | Washing Machines
    Machine fills and agitates, but won't drain
    Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
    Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
    GE Potscrubber Disshwasher GSD700G, wont cycle
    Most washers do not fill they spray the dishes. When enough water has accumulated in the bottom a float switch shuts off the water and turns on the pump to remove the water. If the pump motor does not remove the water the cycle will not continue but the timer will. There may be something clogging the pump and resulting in an overload condition for the motor. This would account for the smell. A pump may turn freely when you spin it by hand because you cannot spin it fast enough by hand to determine if the pump is obstructed. Does the cycle drain the water? If the cycle stops and there is water in the bottom not being pumped out then you should look at the pump and the motor to determine problem.
    Jan 19, 2008 | GE 24 in. GSD2230Z Built-in Dishwasher
    Kenmore 24032\24036 Top Load Washer Logo
    71 people viewed this question
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
