In my message box on the copier it says Stack 100% and then there are like 4 little boxes
SOURCE: Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
SOURCE: icons
This is a Blackberry Curve, right?
We're going to need more description before we can help:
1. Where are the boxes located on the screen?
2. Are they there all the time or just when you're in a certain section (like email)?
3. Do you notice any pattern to the green / red switch? Like maybe you're not receiving email or data when the box is red?
The battery gauge does show red when the battery is very low.
Maybe you could take a picture and post it with your problem description?
SOURCE: Brother 210 C Unable to Clean message appears in
Probably it's waste ink tank is full.
Try this:
1. Pres 'menu', 'mono start' then
'menu' one by one...
2. Press the arrow up or down to go to
'maintenance 80'.
3. Press 'mono start' several times to go to
'Purge'. Finding the PURGE will show some numeric value which is I
assume the number of times the printer had cleaned.
4. Press
'arrow up' key and scroll for number "2" then press "set".
Do the same for numbers 7, 8 and 3. After you have entered this
combination, the purge numeric value will be reseted to 00000.
SOURCE: I turned on my Brother MFC-7440N and
By the sound of it, it sounds like the drum for the laser printer is just about shot. Time to get another cartdrige.
Testimonial: "thanx - I have very little knowledge and any suggestion is appreciated"
SOURCE: I'm receiving error message 46
Welcome to Fixya. To fix error 46 on borhter printer please follow the steps below.
1) Enter machine maintenance mode
- FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
- Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Thanks for using Fixya.
