SOURCE: working one set of Vtech 6041 cordless phone set with another?
I have the vtech dect6.0 with one answering system and two remote docking systems.I can phone out from the remotes but cannot receive incoming calls from the remote.When I pick up the remote to receive the phone immediately shuts off.
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
SOURCE: Can I use Bluetooth headset on Bluetooth enabled land-line phone?
See:http://www.testfreaks.com/blog/review/vtech-ls6245-cordless-phone-with-bluetooth/. Looks like you could at least with this one. I am also looking to do the same.
SOURCE: I have a belkin router, cordless phone interferce
cordless phones and wireless routers transmit on the same frequency. Move the router away from the cordless phone if it's near, if not try changing the channel on your belkin router
Now if your WIRELESS connection drops, when the phone rings it's usually because of this:
You have a cordless phone in your house that is using the same
channel as your wireless router. Now routers are generally quite
different so there's no one way to fix this. Just look up your make and
model of modem on Google and find out how to change the channel on your
modem. It's pretty straight forward and not very time consuming to fix.
Also one thing to note is that you shouldn't automatically jump to
the highest channel that you can because your wireless card may not be
able to go that high.
my vt phone is lock and need to unlock it help
