Question about One For All URC-3021 Remote Control
I need to know how too program a sony home theatre dvd system
To my oneforall remote
  • 259 Answers
Re: i need to know how too program a sony home theatre...
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
Posted on Dec 12, 2007
0 characters
3 Points
How can I get the Sony DVD home theater TO WORK ON MY UNIVERSAL REMOTE?
Universal remote codes Home theatre
Aiwa = 0641, 1912
Anam = 1913
Apex Digital = 1915, 1937
Audiovox = 0790
Cambridge Soundworks = 1916
Classic = 1917
Daewoo = 1918
Fisher = 1919
Gradiente = 0651
Initial = 1931
Integra = 1924
JBL = 1926
JVC = 1901
KLH = 0790
Koss = 0651
Magnavox = 1914
Norcent = 1923
Onkyo = 1924
Oritron = 0651
Panasonic = 1907, 1908, 1909, 1910
Philips = 1914
Qwestar = 0651
RCA = 0790, 1913
Samsung = 1932
Shinsonic = 1931
Sony = 1903, 1904
Venturer = 0790
Sep 29, 2015 | Philips Phillips SRP1103/27 3-Device...
I need to find the codes for the sony dvd player on the urc-3021B00 remote
Try the codes: 0533 1533 0864 1033 for a Sony DVD player.
The code list for the URC-3021 is available from One For All here: . The manual and the code list is available here: .
Please note that the codes available in a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a new remote. The first URC-3021 was released in 2004.
I hope this helps.
Oct 19, 2011 | Remote Controls
I just need the codes
Try this website, the instruction manual & code manual links are right below the picture of the remote.
Dec 10, 2009 | One For All URC4220 Remote Control
Remote Control Programming
it is so good to hear from you friend. the replacement remote that you need is on the number that you are looking for is 148058621. this remote cost 24.95. thank you for writing and please rate my solution.
Nov 18, 2009 | Sony Remote Controls
UNIVERSAL REMOTE Needed for TV, Home Theatre System & DVD Player
Try maplin...there are a number of 'ONE FOR ALL' remote controls which will do your tv, radio, sky box, cable what you will have to do is program it with the codes for the particular item. the codes are usually supplied in the user manual with the remote.
Nov 28, 2008 | Remote Controls
After getting the proper codes from your manual or Customer Service, use the following instructions to enter them into your remote.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER the 4 digit code for your brand.
  4. You should receive 2 quick flashes after entering your code.
  5. PRESS the POWER button to test the code. (On VCR, LD, and CD players use PLAY)
May 23, 2008 | Universal Remote Control DIRECTV Universal...
Remote code for Sony Homethetre on LG Remote
Dec 30, 2007 | Remote Controls
Programming codes
This link has the manual:
Feb 24, 2007 | Jensen JR500 Remote Control
One For All URC-3021 Remote Control Logo
49 people viewed this question
Top One For All Remote Controls Experts
Are you an One For All Remote Control Expert? Answer questions, earn points and help others
