Question about Cycling
Tire removal How do I remove the front tire of my mountain bike? I have no idea how to release the brakes.
  • 132 Answers
Depends on what kind of brakes you have cable or traditional cable compress them and the cable will come out traditional there is a bolt in the center loostn it and they will release
Posted on Jul 23, 2009
How do I remove the front tire of my Trek Fuel Ex 7 29?
Check youtube my friend, there are great instructional videos there.Remove wheel from front forks, release any air from tyre, using 2 plastic tyre removal tools to remove tyre. Further instructions will be found on youtube.
Aug 28, 2017 | Trek Cycling
How do I change the front tire with disk brake on a genesis v2100
Change it as with any other bike; make sure no grease on the disk.
Sep 28, 2015 | Genesis 26 Inch V2100 Dual-Suspension...
Quick release bike tire installation
the pads don't need to be removed. Most brakes have a "quick release" on them. On linear pull brakes, use one hand to squeeze the two lever against the rim and with your other hand you can pull the "L" shaped cable noodle out the bracket and this releases the brakes. (you can also let the air out of the tire and install the wheel then reinflate the tire once you have it back on the bike). On road bikes with side-pull brakes most have a small lever you can flip up that activates a cam mechanism that opens the brakes up to allow the tire to pass through. Canti-lever brakes are similar to linear-pull brakes, just squeeze the brakes together and release the straddle cable. Hope this helps.
Aug 13, 2014 | Cycling
How to release the brake to remove the rear tire
You asked about releasing the rear brake but posted a picture of the rear derailleur. Clarification would be very helpful.
May 15, 2014 | Shimano 09 Xtr M971lc Mountain Bike Rear...
I have a Schwinn Ditch mountain bike with front disc brakes and a quick release front tire. I pooped the tire off using the quick release on the hub and the tire simply slipped off and out of the disc...
You have to bleed the break fluid on your break and press the pads on both sides then insert the disc. When you bleed the break fluid do not press the lever.
Apr 10, 2011 | Schwinn Cycling
I have an otero mongoose bike how do i take the front tire off
The front wheel is removed by releasing the quick release located at the bottom of the fork. The tire can be removed by deflating the tire and then levering off the tire itself using a set of special removal tools.
Jun 04, 2010 | Mongoose 2009 Otero Comp Mountain Bike...
Frontier GSX Women's Mountain Bike: what is proper way to remove and re-install the qu...
Unhook the front brake, loose the quick release level and push the tire off the fork. reverse procedure to install.
May 16, 2010 | Schwinn Frontier GSX Women's Mountain Bike
How do you change a innertube on a back wheel of a mountain bike
You have to remove the entire wheel from the bike. Then change it just like you'd change a front tire... remove oneside of the tire from the rim, pull out bad tube, clean rim, put in new tube, put tire back on rim, inflat tube... good to go. There are 1,000,000 videos on YouTube to show you this process.
Nov 08, 2009 | Bike Extreme Lite Youth Shoulder Pad
Removing front wheel from harley davidson heritage softail
first take off the brake caliper takes a 10 mm socket..Next jack front of bike up just enough to take pressure off front tire...take off the axle nut lbit more to take pressure off axleock washer and flat washer...Next remove two axle support nuts from the right side of bike 1/2 in socket. now jack bike up a hair more to releave pressure off axle push, hammer with a rubber hammer or what ever it takes to drive it through. jack bike up so it clears fender. Sometimes the tire won't clear the fender bolts if so just release air from tire and it will clear. good luck. Its not hare at all.
Jun 08, 2009 | 2000 Harley Davidson FLSTC Heritage...
Cycling Logo
75 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
