Question about Hotpoint HSS25GFP Side by Side Refrigerator
My frige stays warm all the time
Hotpoint problem
  • 6,784 Answers
HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. CAUTION: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
The condensor coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. thsi will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
Next will be the door switch. The interior light in most refrigerators, and the fan in some, is controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device and thermostat.
Posted on Jul 23, 2009
Hotpoint FFA71 frige/freezer red light on freezer does not freeze but does stays cold, frige cooler than usual with frost, freezer fan runs for a short time, it does appear to defrost and motor is on...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 15, 2011 | Refrigerators
The freezer side is working fine but the refrigerator side is warm and not cooling well
its normal for a frige to get warm when its new run wait until your evaforating section is full of ice then you will notice that side of your frige will get the normal heat.... to stay in automatic mode
Aug 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Hotpoint Refrigerator keeps popping the outlet breaker and shutting off. I took the rear vent grate off to clean any dust out and noticed there is about a 1/8" of water sitting. Is this what could be...
Normally if the fridge is tripping the circuit breaker, it is due to a short caused by the defrost element.
However, the second problem could be caused by a faulty timer.
Ash
Oct 22, 2009 | Hotpoint Refrigerators
My frige stays warm all the time it is a Hotpoint
evaporator coils are iced up on the freezer side. either take everything out of the fridge and unplug it and let it sit for a day to defrost, or remove the inside rear panel where there is frost and (with the fridge off) use warm water sprayed on the ice to defrost it (or use a hair dryer, but just until the ice is melted. do not overheat the metal). soak up the excess water (underneath the fridge, too), and turn it on empty. let it run empty for a day to get it cold, then put the stuff back in. if the stuff is in there when it's warm, the humidity will ice up the coils again.
Jul 23, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator is warm and freezer is cold
www.complaintsboard.com/.../samsung-refrigerator-c530.html
Jun 22, 2009 | Hotpoint  16.6 Cu. Ft. Top-Freezer...
I have kenmore side by side it seem very warm between frige and frezer by door handle never felt warm before (26foot elite) about 4 years old
i pulled the frige out to clean around the coils only to find the cooling fan was not hooked back up buy the last repair man that changed a thermostat a month ago be for i put my tool away it was ok
Feb 20, 2009 | Hotpoint HSM25GFRSA
Freezer is ok nice and cold but frige seems warm?
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
But, I did not recieve a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Aug 05, 2008 | Hotpoint HSS25GFP Side by Side...
How to replace the freon in a hotpoint refrigerator
I replaced leaking evaporator coil in this video and charged it with freon R134a
Aug 28, 2007 | GE Hotpoint Top-Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
237 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
