Question about Boating
Need wiring diagram for 1994 Evinrude outboard, Model E70TLERV.
  • 2692 Answers
SOURCE: gear box oil leak
Here is a website where a manual for you outboard may be purchased.  Outboard Marine went out of buisness in 2000 and thus no parts of origial manufacture are support is available . Therir are secondary markets .    THe Lower case splits in half and their is a seal around the prop shiftm which is pressed in. The seal between the cases are cut o-rings which are placed and glued into place with gasket seal.
The water pump is located where the case splits a little bit higher. You must open the little port on the side and take out one of the screws to the connecting shift linkage to split the case. After splitting the case the drive shaft and water pickup tube(s) wil come out of the powwer head or the tubs may stick into the power head which is ok. Place the lower skag into a vice and remove the 4 or 5 screws to the water pump housing. Remove and replace impellor and impellor plate if available. If part(pieces) of the rubber impellor is missing flush out the tubes and the power head to remove them.   When reinstalling the lower unit use a flash light to make sure that the tubes return  to the proper place in the power head and the shift lever is resecured. If you need more assistance, just write back. I was an Outboard motor mechanic for five years about the time of your motor.
Posted on Dec 23, 2008
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
  • 57 Answers
SOURCE: cant find how to tilt evinrude outboard
have you got hydraulic trim/tilt? if so control button /switch will be on or near throttle handle-if not you will have to manually lift and insert pin at bottom of mount on transom
Posted on Oct 15, 2009
  • 42991 Answers
SOURCE: Are 1975 and 1977, 55HP Evinrude outboard motors compatible
yes they are on most parts
Posted on Apr 26, 2010
  • 3 Answers
SOURCE: iam looking for a wiring diagram for a 1964 40
Here is a link to the diagram you need.
http://www.maxrules.com/graphics/omc_pics/wiring/61_66_40HP.jpg
Posted on Apr 28, 2010
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
HOW DO I TELL THE AGE OF MY EVINRUDE OUTBOARD
get the serial number then go google and type in -- serial numbers of evinrude outboard motors-- and select a site where you enter your serial number
or you take your serial number to an evinrude/ johnson outboard dealer and have them look it up
Sep 19, 2016 | Boating
I need an owners manual for an Evinrude 2 HP outboard motor model 2402E.
http://shop.evinrude.com/category/342499/Literature?brand=27153&horsepower=6955&year=27400&n=0&x=21&y=20
For Evinrude service manuals or Evinrude Johnson owners manuals for 1999 models and prior, please contact the Ken Cook Company at (414) 466-6060 or click here to be directed to their website Antique Literature. On older literature, original printed copies may no longer be available. When this occurs, an effort will be made to fulfill your order with a machine copy reproduced from a master file.
This says it is 1974
https://www.marineengine.com/manuals/evinrude/#e2hp
http://www.ebay.com/itm/1980-2hp-Johnson-Outboard-Repair-Manual-Evinrude-2-HP-/190470229931
Original outboard product and service manuals for Johnson Evinrude Gale...
Aug 07, 2016 | Boating
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 | Boating
I need information on an evinrude outboard unsure of year or HP serial number is 4416-03315
Sounds like it could be an Evinrude Sportsman model 4416. Here's the info I found online:
  • Model: Sportsman - 4416
  • Make: Evinrude Motor Co.
  • Inboard/Outboard: Outboard
  • Engine Type: Gasoline
  • Production Date: 1947
  • Engine Design: Two-Stroke
  • Horsepower: 2.0
Check google search for pictures and more info on it!
4416 evinrude Google Search
Jun 16, 2015 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
I need to find and print out a wiring diagram for a 55 horsepower
here is the direct link to evinrude. There you will find what you are seeking.
http://www.evinrude.com/en-US/
Sep 14, 2009 | Boating
I am looking for a diagram of a 1977 evinrude 85hp engine - so i can work out how to remove the tilt rams from the engine to check if they are working correctly
Hi there, You can find all parts diagrams for Evinrude engines here: http://epc.brp.com Just ignore the email entry part and go straight to the database. They are listed by Brand, then year, then HP size. I checked for you and it has the 1977 85HP models listed there. Then just find the right subsection of the outboard and it will bring up exploded diagrams for your viewing!
Jun 15, 2009 | Boating
Boating Logo
990 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
